Saltar al contenido principal
Canon PowerShot A75 Casing Replacement
Qué necesitas
  1. Canon PowerShot A75 Casing Replacement, Batteries: paso 1, imagen 1 de 1
    • Turn the camera over and locate the "BATT OPEN" sliding switch.
  2. Canon PowerShot A75 Casing Replacement: paso 2, imagen 1 de 3 Canon PowerShot A75 Casing Replacement: paso 2, imagen 2 de 3 Canon PowerShot A75 Casing Replacement: paso 2, imagen 3 de 3
    • Slide the switch to the right.
    • The battery cover should slide down and spring open.
  3. Canon PowerShot A75 Casing Replacement: paso 3, imagen 1 de 3 Canon PowerShot A75 Casing Replacement: paso 3, imagen 2 de 3 Canon PowerShot A75 Casing Replacement: paso 3, imagen 3 de 3
    • Remove the 4 AA batteries.
    • Watch for the orientation of the batteries as they slide out.
    • The battery orientation is shown under the battery flap itself and on a sticker next to the battery flap.
  4. Canon PowerShot A75 Casing Replacement, Casing: paso 4, imagen 1 de 1
    • Remove the three 2.5mm screws on the bottom of the camera.
  5. Canon PowerShot A75 Casing Replacement: paso 5, imagen 1 de 1
    • Remove the 3.8mm screw underneath the flap that covers the A/V port.
  6. Canon PowerShot A75 Casing Replacement: paso 6, imagen 1 de 2 Canon PowerShot A75 Casing Replacement: paso 6, imagen 2 de 2
    • Remove the 2.4mm screw located underneath the cover of the memory card slot.
  7. Canon PowerShot A75 Casing Replacement: paso 7, imagen 1 de 2 Canon PowerShot A75 Casing Replacement: paso 7, imagen 2 de 2
    • Open the memory card slot by sliding it laterally until you hear a click.
    • Remove the 5.9mm screw in the upper corner of the memory card slot.
  8. Canon PowerShot A75 Casing Replacement: paso 8, imagen 1 de 1
    • Remove the two 4.1mm screws at the bottom of the battery flap.
  9. Canon PowerShot A75 Casing Replacement: paso 9, imagen 1 de 2 Canon PowerShot A75 Casing Replacement: paso 9, imagen 2 de 2
    • Lift the shutter button and speaker part from the top of the camera.
    • DO NOT pull the part too hard because there is a plug connecting the speaker to the camera.
  10. Canon PowerShot A75 Casing Replacement: paso 10, imagen 1 de 3 Canon PowerShot A75 Casing Replacement: paso 10, imagen 2 de 3 Canon PowerShot A75 Casing Replacement: paso 10, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Using a pair of tweezers, grab the plug that connects the speaker to the camera and gently pull it out.
  11. Canon PowerShot A75 Casing Replacement: paso 11, imagen 1 de 1
    • Remove the rightmost 4.2mm screw underneath the battery cover, not the center screw.
  12. Canon PowerShot A75 Casing Replacement: paso 12, imagen 1 de 3 Canon PowerShot A75 Casing Replacement: paso 12, imagen 2 de 3 Canon PowerShot A75 Casing Replacement: paso 12, imagen 3 de 3
    • Separate the back casing and front casing of the camera using your hands.
    • Pulling the two halves apart can be difficult, especially at the top. Use a moderate amount of force.
  13. Canon PowerShot A75 Casing Replacement: paso 13, imagen 1 de 3 Canon PowerShot A75 Casing Replacement: paso 13, imagen 2 de 3 Canon PowerShot A75 Casing Replacement: paso 13, imagen 3 de 3
    • On the front of the camera, press the button on the lower left of the lens.
    • Twist the outer lens casing counter-clockwise and slide it out.
  14. Canon PowerShot A75 Casing Replacement: paso 14, imagen 1 de 3 Canon PowerShot A75 Casing Replacement: paso 14, imagen 2 de 3 Canon PowerShot A75 Casing Replacement: paso 14, imagen 3 de 3
    • Take off the front casing.
    • There is a black rubber washer around the lens that comes out after you take the casing off. Make sure to replace it when putting the camera back together.
Conclusión
4 personas más completaron esta guía.
Equipo
Cal Poly, Team 17-30, Amido Spring 2012 Miembro de Cal Poly, Team 17-30, Amido Spring 2012
CPSU-AMIDO-S12S17G30
5 Miembros
12 Guías creadas
Un comentario
Thank you for this detailed guide. It helped me to gain access to the electrical contacts in the battery compartment to remove alkaline battery corrosion
Jef B - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 10
Todo El Tiempo: 1,525
