Saltar al contenido principal
Canon PowerShot A75 Batteries Replacement
  1. Canon PowerShot A75 Batteries Replacement, Batteries: paso 1, imagen 1 de 1
    • Turn the camera over and locate the "BATT OPEN" sliding switch.
  2. Canon PowerShot A75 Batteries Replacement: paso 2, imagen 1 de 3 Canon PowerShot A75 Batteries Replacement: paso 2, imagen 2 de 3 Canon PowerShot A75 Batteries Replacement: paso 2, imagen 3 de 3
    • Slide the switch to the right.
    • The battery cover should slide down and spring open.
  3. Canon PowerShot A75 Batteries Replacement: paso 3, imagen 1 de 3 Canon PowerShot A75 Batteries Replacement: paso 3, imagen 2 de 3 Canon PowerShot A75 Batteries Replacement: paso 3, imagen 3 de 3
    • Remove the 4 AA batteries.
    • Watch for the orientation of the batteries as they slide out.
    • The battery orientation is shown under the battery flap itself and on a sticker next to the battery flap.
Conclusión
Put in fresh batteries. Gently shut the flap and slide it forward until you hear a click.
Equipo
Cal Poly, Team 17-30, Amido Spring 2012 Miembro de Cal Poly, Team 17-30, Amido Spring 2012
CPSU-AMIDO-S12S17G30
5 Miembros
12 Guías creadas
3 comentarios
Hi, there is a problem with my Powershot a75. Whenever I switch it on, it just says change the batteries even though they are either new, or fully charged. Thanks
Harry collier - Contestar
had same trouble i fix it buy pressing the print button on back next to the disp button it should work then
hot5 - Contestar
Probably you have change backup battery which is rechargeable and not easy to change. It is close to chargeable outlet.
Maganbhai Patel - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 22
Ultimos 30 días: 41
Todo El Tiempo: 2,246
