Saltar al contenido principal
Canon PowerShot A630 Front Panel Replacement
Qué necesitas
  1. Canon PowerShot A630 Front Panel Replacement, Front Panel: paso 1, imagen 1 de 2 Canon PowerShot A630 Front Panel Replacement, Front Panel: paso 1, imagen 2 de 2
    • Open the battery door by sliding the tab on the battery door while pushing the battery door away from the camera.
    • Remove batteries.
  2. Canon PowerShot A630 Front Panel Replacement: paso 2, imagen 1 de 2 Canon PowerShot A630 Front Panel Replacement: paso 2, imagen 2 de 2
    • Remove the three indicated .2mm screws using a Phillips #00 screwdriver.
    • Gently pull off side-panel to remove it.
  3. Canon PowerShot A630 Front Panel Replacement: paso 3, imagen 1 de 1
    • Remove the two indicated .2mm screws using a Phillips #00 screwdriver.
  4. Canon PowerShot A630 Front Panel Replacement: paso 4, imagen 1 de 2 Canon PowerShot A630 Front Panel Replacement: paso 4, imagen 2 de 2
    • Remove the indicated .2mm screw using a Phillips #00 screwdriver.
    • Remove the three .2mm screws located on the internal side of the top panel within the battery chamber using a Phillips #00 screwdriver.
  5. Canon PowerShot A630 Front Panel Replacement: paso 5, imagen 1 de 2 Canon PowerShot A630 Front Panel Replacement: paso 5, imagen 2 de 2
    • Open 'DIGITAL A/V OUT' door on camera.
  6. Canon PowerShot A630 Front Panel Replacement: paso 6, imagen 1 de 1
    • Grip the sides of the top panel and gently pull to separate the top panel from the camera body.
    • The top panel will not completely detach.
  7. Canon PowerShot A630 Front Panel Replacement: paso 7, imagen 1 de 2 Canon PowerShot A630 Front Panel Replacement: paso 7, imagen 2 de 2
    • Gently pull the front and back panels apart, and use a Phillips #00 screwdriver to remove the screw connecting the panels.
    • Gripping the top and bottom, gently pull the front panel away from the camera body to remove it.
Conclusión
4 personas más completaron esta guía.
Kelly Duggan
Miembro Desde 10/13/14
460 Reputación
3 Guías creadas
Equipo
Clemson, Team 2-5, Benson Fall 2014 Miembro de Clemson, Team 2-5, Benson Fall 2014
CLEM-BENSON-F14S2G5
4 Miembros
18 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 8
Todo El Tiempo: 856
