Saltar al contenido principal
Canon PowerShot A620 Shutter Button Replacement
Qué necesitas
  1. Canon PowerShot A620 Shutter Button Replacement, Side Panel: paso 1, imagen 1 de 3 Canon PowerShot A620 Shutter Button Replacement, Side Panel: paso 1, imagen 2 de 3 Canon PowerShot A620 Shutter Button Replacement, Side Panel: paso 1, imagen 3 de 3
    • Unscrew the three Phillips #00 1.6x3mm screws on the side.
    • Lift loose panel from the case.
    • Unscrew the two Phillips #00 1.6x3mm screws that were previously hidden beneath the panel.
  2. Canon PowerShot A620 Shutter Button Replacement, Bottom Panel: paso 2, imagen 1 de 1
    • Unscrew the two Phillips #00 1.6x3mm screws on the bottom panel.
  3. Canon PowerShot A620 Shutter Button Replacement, Battery Compartment: paso 3, imagen 1 de 1
    • Open the battery door.
    • Unscrew the four Phillips #00 1.6x3mm screws in the battery compartment.
  4. Canon PowerShot A620 Shutter Button Replacement, Terminal Cover: paso 4, imagen 1 de 2 Canon PowerShot A620 Shutter Button Replacement, Terminal Cover: paso 4, imagen 2 de 2
    • Lift the terminal cover on the side of the camera.
    • Unscrew the three Phillips #00 1.6x3mm screws beneath the terminal cover.
  5. Canon PowerShot A620 Shutter Button Replacement, Top Panel: paso 5, imagen 1 de 1
    • Gently pull the top panel to separate it from the case.
    • Although the top panel will now be free from the rest of the case, it will still be attached to the camera by a ribbon cable.
  6. Canon PowerShot A620 Shutter Button Replacement, Front Panel: paso 6, imagen 1 de 2 Canon PowerShot A620 Shutter Button Replacement, Front Panel: paso 6, imagen 2 de 2
    • Gently pull the front panel to separate it from the camera.
    • The battery terminals are easy to access from this step.
  7. Canon PowerShot A620 Shutter Button Replacement, Terminal Cover: paso 7, imagen 1 de 2 Canon PowerShot A620 Shutter Button Replacement, Terminal Cover: paso 7, imagen 2 de 2
    • Gently pull the terminal cover to separate it from the camera.
  8. Canon PowerShot A620 Shutter Button Replacement, Memory Card Cover: paso 8, imagen 1 de 2 Canon PowerShot A620 Shutter Button Replacement, Memory Card Cover: paso 8, imagen 2 de 2
    • Slide the memory card cover down.
    • Unscrew the Phillips #00 1.6x3mm screw beneath the memory card cover.
  9. Canon PowerShot A620 Shutter Button Replacement, Back Panel: paso 9, imagen 1 de 2 Canon PowerShot A620 Shutter Button Replacement, Back Panel: paso 9, imagen 2 de 2
    • Gently pull the back panel to separate it from the camera.
  10. Canon PowerShot A620 Shutter Button Replacement, Metal Plate Screws: paso 10, imagen 1 de 2 Canon PowerShot A620 Shutter Button Replacement, Metal Plate Screws: paso 10, imagen 2 de 2
    • Unscrew the Phillips #00 1.6x3mm screw located on the top panel.
  11. Canon PowerShot A620 Shutter Button Replacement, Metal Plate: paso 11, imagen 1 de 1
    • Gently lift the metal plate and move it to the side.
  12. Canon PowerShot A620 Shutter Button Replacement, Trigger Button Screws: paso 12, imagen 1 de 2 Canon PowerShot A620 Shutter Button Replacement, Trigger Button Screws: paso 12, imagen 2 de 2
    • Unscrew the two Phillips #00 1.6x3mm screws that hold in the trigger button.
  13. Canon PowerShot A620 Shutter Button Replacement, Trigger Button: paso 13, imagen 1 de 1
    • The trigger button will fall off once the screws have been removed.
Conclusión
Una persona más ha completado esta guía.
Jaime Abraham
Miembro Desde 09/08/14
350 Reputación
3 Guías creadas
Equipo
CSU Fullerton, Team 1-1, Bruce Fall 2014 Miembro de CSU Fullerton, Team 1-1, Bruce Fall 2014
CSUF-BRUCE-F14S1G1
3 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 15
Todo El Tiempo: 1,430
