Saltar al contenido principal
Canon PowerShot A620 Camera Housing Replacement
Qué necesitas
  1. Canon PowerShot A620 Camera Housing Replacement, Open Battery Door: paso 1, imagen 1 de 3 Canon PowerShot A620 Camera Housing Replacement, Open Battery Door: paso 1, imagen 2 de 3 Canon PowerShot A620 Camera Housing Replacement, Open Battery Door: paso 1, imagen 3 de 3
    • Slide the tab on the battery door while pushing the battery door away from you. The battery door should pop open.
  2. Canon PowerShot A620 Camera Housing Replacement, Insert Batteries: paso 2, imagen 1 de 2 Canon PowerShot A620 Camera Housing Replacement, Insert Batteries: paso 2, imagen 2 de 2
    • Insert AA batteries according to the diagram printed on the camera.
    • Close the battery door.
  3. Canon PowerShot A620 Camera Housing Replacement, Side Panel: paso 3, imagen 1 de 3 Canon PowerShot A620 Camera Housing Replacement, Side Panel: paso 3, imagen 2 de 3 Canon PowerShot A620 Camera Housing Replacement, Side Panel: paso 3, imagen 3 de 3
    • Unscrew the three Phillips #00 1.6x3mm screws on the side.
    • Lift loose panel from the case.
    • Unscrew the two Phillips #00 1.6x3mm screws that were previously hidden beneath the panel.
  4. Canon PowerShot A620 Camera Housing Replacement, Bottom Panel: paso 4, imagen 1 de 1
    • Unscrew the two Phillips #00 1.6x3mm screws on the bottom panel.
  5. Canon PowerShot A620 Camera Housing Replacement, Battery Compartment: paso 5, imagen 1 de 1
    • Open the battery door.
    • Unscrew the four Phillips #00 1.6x3mm screws in the battery compartment.
  6. Canon PowerShot A620 Camera Housing Replacement, Terminal Cover: paso 6, imagen 1 de 2 Canon PowerShot A620 Camera Housing Replacement, Terminal Cover: paso 6, imagen 2 de 2
    • Lift the terminal cover on the side of the camera.
    • Unscrew the three Phillips #00 1.6x3mm screws beneath the terminal cover.
  7. Canon PowerShot A620 Camera Housing Replacement, Top Panel: paso 7, imagen 1 de 1
    • Gently pull the top panel to separate it from the case.
    • Although the top panel will now be free from the rest of the case, it will still be attached to the camera by a ribbon cable.
  8. Canon PowerShot A620 Camera Housing Replacement, Front Panel: paso 8, imagen 1 de 2 Canon PowerShot A620 Camera Housing Replacement, Front Panel: paso 8, imagen 2 de 2
    • Gently pull the front panel to separate it from the camera.
    • The battery terminals are easy to access from this step.
  9. Canon PowerShot A620 Camera Housing Replacement, Terminal Cover: paso 9, imagen 1 de 2 Canon PowerShot A620 Camera Housing Replacement, Terminal Cover: paso 9, imagen 2 de 2
    • Gently pull the terminal cover to separate it from the camera.
  10. Canon PowerShot A620 Camera Housing Replacement, Memory Card Cover: paso 10, imagen 1 de 2 Canon PowerShot A620 Camera Housing Replacement, Memory Card Cover: paso 10, imagen 2 de 2
    • Slide the memory card cover down.
    • Unscrew the Phillips #00 1.6x3mm screw beneath the memory card cover.
  11. Canon PowerShot A620 Camera Housing Replacement, Back Panel: paso 11, imagen 1 de 2 Canon PowerShot A620 Camera Housing Replacement, Back Panel: paso 11, imagen 2 de 2
    • Gently pull the back panel to separate it from the camera.
Conclusión
2 personas más completaron esta guía.
Jaime Abraham
Miembro Desde 09/08/14
350 Reputación
3 Guías creadas
Equipo
CSU Fullerton, Team 1-1, Bruce Fall 2014 Miembro de CSU Fullerton, Team 1-1, Bruce Fall 2014
CSUF-BRUCE-F14S1G1
3 Miembros
6 Guías creadas
Un comentario
Ottima spiegazione: é tutto facile quando la spiegazione é semplice ed univoca. Ma redigere istruzioni semplici é un'arte che non tutti possiedono.
Paolo Ravera - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 21
Todo El Tiempo: 1,764
