Introducción
This guide will instruct you how to remove the front and back covers from the camera and disassemble the flash in order to replace or repair it.
Herramientas
Partes
No se especificaron partes.
The battery hatch is on the bottom of the camera.
While the switch is pushed forward, pull the cover away from the camera.
This camera requires AA batteries. To remove batteries, simply allow them to fall out of the camera.
The clock battery cover is shown here in the purple circle. Use a fingernail to lift the battery out of the camera.
When replacing the AA batteries, verify they are oriented correctly by following the (+) and (-) signs on the camera.
Remove the screw located under the rubber flap on the left side of the camera using a magnetic screwdriver.
Remove the two screws located on the other side of the camera using a magnetic screwdriver
Remove the three screws located at the bottom of the camera using a magnetic screwdriver.
Open the battery cover.
Using the iPod tool, push up gently around all edges of the camera.
Press and hold down the button shown in the blue circle.
While pressing the button, rotate the lens cover in a counter-clockwise direction to remove it.
Remove the one (1) screw from the top of the camera, on the left side of the flash (looking from the front) using a Phillips #00 screwdriver.
Lift the black plastic covering off the circuit board.
Remove the green circuit board from the top. Looking from the front of the camera, first lift the left side up above the black peg. The board should then slide out to the left.
3 personas más completaron esta guía.
2 comentarios
If it is the flash element that needs to be replace, I presume I will see it when I’m there.
Is this correct ?
effitech_structure@yahoo.com
