Saltar al contenido principal
Canon PowerShot A590 IS Clock Battery Replacement
Qué necesitas
  1. Canon PowerShot A590 IS Clock Battery Replacement, Batteries: paso 1, imagen 1 de 2 Canon PowerShot A590 IS Clock Battery Replacement, Batteries: paso 1, imagen 2 de 2
    • The battery hatch is on the bottom of the camera.
    • CAUTION: Locate the switch to open the hatch and push gently toward the front of the camera. Too much force can break the hatch.
    • While the switch is pushed forward, pull the cover away from the camera.
  2. Canon PowerShot A590 IS Clock Battery Replacement: paso 2, imagen 1 de 1
    • This camera requires AA batteries.
    • To remove batteries, simply allow them to fall out of the camera.
    • Use a fingernail to lift the clock battery out of the camera.
  3. Canon PowerShot A590 IS Clock Battery Replacement: paso 3, imagen 1 de 1
    • When replacing the AA batteries, verify they are oriented correctly by following the (+) and (-) signs on the camera.
  4. Canon PowerShot A590 IS Clock Battery Replacement, Locate Clock Battery: paso 4, imagen 1 de 1
    • To access the clock battery, find the clock battery cover, shown here in the red square.
  5. Canon PowerShot A590 IS Clock Battery Replacement, Remove Battery Tab: paso 5, imagen 1 de 1
    • When accessing the clock battery, use a fingernail or similar small instrument to gently pull the tab out.
  6. Canon PowerShot A590 IS Clock Battery Replacement, Remove Battery from Tab: paso 6, imagen 1 de 1
    • Now that you have the tab and battery removed, use a fingernail or other small tool to remove the battery from the tab.
    • This battery is a CR1220 type watch battery.
  7. Canon PowerShot A590 IS Clock Battery Replacement, Replacing Clock Battery: paso 7, imagen 1 de 1
    • When replacing the clock battery, be sure to have the battery oriented properly, as shown in the picture.
    • Remember, the tab goes in with the exposed side of the battery facing towards the lens.
Conclusión
13 personas más completaron esta guía.
Matt Wolfe
Miembro Desde 10/11/10
411 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 9-19, Regan Fall 2010 Miembro de Cal Poly, Team 9-19, Regan Fall 2010
CPSU-REGAN-F10S9G19
4 Miembros
14 Guías creadas
9 comentarios
thanks its very useful forme
srikrishnan2003 - Contestar
thank you, very useful for my old camera :)
agungsp2000 - Contestar
Perfect! I never even knew I had this battery in there. Couldn't figure out why the date and time wouldn't stay set every time I shut it off. And then I found the answer here.
Thank you very much for the post!
sherlock261 - Contestar
I'm a senior citizen and am not very good with modern technology. Been going crazy trying to set my clock in my digital camera. I didn't want to buy a new one because I have had this one for years (Power Shot A590) and didn't want to have to learn to use a newer one. Finally got smart enough to do a google search for an answer. Will get a new battery tomorrow and solve my problem. Thanks for the help!...the information age is good for something after all.
Pat Solomon - Contestar
Wow this is a great site. I got the answer I needed right away. The instructions were clear, simple and correct. Thank you.
You are bookmarked.
jeffrey wales - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 22
Ultimos 30 días: 58
Todo El Tiempo: 15,765
