Saltar al contenido principal
Canon PowerShot A590 IS Back Cover Replacement
Qué necesitas
  1. Canon PowerShot A590 IS Back Cover Replacement, Batteries: paso 1, imagen 1 de 2 Canon PowerShot A590 IS Back Cover Replacement, Batteries: paso 1, imagen 2 de 2
    • The battery hatch is on the bottom of the camera.
    • CAUTION: Locate the switch to open the hatch and push gently toward the front of the camera. Too much force can break the hatch.
    • While the switch is pushed forward, pull the cover away from the camera.
  2. Canon PowerShot A590 IS Back Cover Replacement: paso 2, imagen 1 de 1
    • This camera requires AA batteries.
    • To remove batteries, simply allow them to fall out of the camera.
    • Use a fingernail to lift the clock battery out of the camera.
  3. Canon PowerShot A590 IS Back Cover Replacement: paso 3, imagen 1 de 1
    • When replacing the AA batteries, verify they are oriented correctly by following the (+) and (-) signs on the camera.
  4. Canon PowerShot A590 IS Back Cover Replacement, Back Cover: paso 4, imagen 1 de 1
    • Remove the screw located under the rubber flap on the left side of the camera using a Phillips #00 screwdriver.
  5. Canon PowerShot A590 IS Back Cover Replacement: paso 5, imagen 1 de 1
    • Remove the two screws located on the other side of the camera using a Phillips #00 screwdriver.
  6. Canon PowerShot A590 IS Back Cover Replacement: paso 6, imagen 1 de 1
    • Remove the three screws located at the bottom of the camera using a Phillips #00 screwdriver.
  7. Canon PowerShot A590 IS Back Cover Replacement: paso 7, imagen 1 de 1
    • Open the battery cover.
    • Using the iFixit opening tool, push up gently around all edges of the camera.
Conclusión
7 personas más completaron esta guía.
Zach
Miembro Desde 10/11/10
281 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 9-19, Regan Fall 2010 Miembro de Cal Poly, Team 9-19, Regan Fall 2010
CPSU-REGAN-F10S9G19
4 Miembros
14 Guías creadas
Un comentario
i just wanted to by flap to replace over batteries it slides on and off reedalice270@gm.com
Alice Reed - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 16
Todo El Tiempo: 8,537
