Saltar al contenido principal
Canon PowerShot A550 LCD Screen Replacement
Qué necesitas
  1. Canon PowerShot A550 LCD Screen Replacement, Front and Back Covers: paso 1, imagen 1 de 3 Canon PowerShot A550 LCD Screen Replacement, Front and Back Covers: paso 1, imagen 2 de 3 Canon PowerShot A550 LCD Screen Replacement, Front and Back Covers: paso 1, imagen 3 de 3
    • Unscrew a total of 6 4.45 mm phillips head screws using a #00 phillips head screwdriver.
    • There are 2 screws on the left side (when looking at the front of the camera).
    • There are 3 screws on the bottom
    • There is 1 screw on the right side
  2. Canon PowerShot A550 LCD Screen Replacement: paso 2, imagen 1 de 1
    • Turn to the bottom of the camera.
    • Open the memory card cover by sliding the "CARD/BATT." button up, and then pulling the cover to the left.
  3. Canon PowerShot A550 LCD Screen Replacement: paso 3, imagen 1 de 1
    • This is what the SD card/battery compartment looks like when opened.
    • Remove one 4.45mm phillips head screw from the SD card/battery compartment using a #00 phillips head screwdriver.
  4. Canon PowerShot A550 LCD Screen Replacement: paso 4, imagen 1 de 2 Canon PowerShot A550 LCD Screen Replacement: paso 4, imagen 2 de 2
    • Gently remove the front cover away from the camera body.
    • Tip: Start by loosening the teeth on the left side of the camera next to the battery compartment.
  5. Canon PowerShot A550 LCD Screen Replacement: paso 5, imagen 1 de 1
    • The camera should look like this once the front cover is removed.
  6. Canon PowerShot A550 LCD Screen Replacement: paso 6, imagen 1 de 3 Canon PowerShot A550 LCD Screen Replacement: paso 6, imagen 2 de 3 Canon PowerShot A550 LCD Screen Replacement: paso 6, imagen 3 de 3
    Herramienta utilizada en este paso:
    • Start from the battery compartment and remove the back cover.
    • Caution: Do not tug on the back cover after it is removed. This could tear the ribbon attaching the back cover to the camera body.
    • Remove the connecting ribbon from the body of the camera using a pair of tweezers.
  7. Canon PowerShot A550 LCD Screen Replacement: paso 7, imagen 1 de 1
    • Once the ribbon connecting the back cover is removed, the back of the camera body should look like this.
  8. Canon PowerShot A550 LCD Screen Replacement, LCD Screen: paso 8, imagen 1 de 1
    • Use a #00 phillips head screwdriver to remove 2 3.34mm phillips screws holding the LCD screen in place.
  9. Canon PowerShot A550 LCD Screen Replacement: paso 9, imagen 1 de 2 Canon PowerShot A550 LCD Screen Replacement: paso 9, imagen 2 de 2
    • Use an iPod Opening Tool to lift the brown portion of the connector to unlock it.
    • Slide the data cable out of the connector.
    • Caution: Do not force the data cable out of the connector. It may rip!
  10. Canon PowerShot A550 LCD Screen Replacement: paso 10, imagen 1 de 1
    • The LCD screen can now be be removed to be fixed/replaced.
Conclusión
2 personas más completaron esta guía.
Precilla Tang
Miembro Desde 04/19/11
177 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 8-6, Regan Spring 2011 Miembro de Cal Poly, Team 8-6, Regan Spring 2011
CPSU-REGAN-S11S8G6
4 Miembros
22 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 13
Ultimos 30 días: 25
Todo El Tiempo: 3,702
