Saltar al contenido principal
Canon PowerShot A540 Front Cover Replacement
Qué necesitas
  1. Canon PowerShot A540 Front Cover Replacement, Back Cover: paso 1, imagen 1 de 2 Canon PowerShot A540 Front Cover Replacement, Back Cover: paso 1, imagen 2 de 2
    • Turn off the camera.
    • Turn the camera upside-down and press the tab to release the battery cover. Remove the batteries.
  2. Canon PowerShot A540 Front Cover Replacement: paso 2, imagen 1 de 1
    • Turn the camera upside down to view the "Card/Batt. Open" Cover.
    • Use a Phillips head #000 screwdriver to remove the three (3) 4.0 mm screws.
  3. Canon PowerShot A540 Front Cover Replacement: paso 3, imagen 1 de 1
    • Open "Card/Batt. Open" Cover.
    • Remove the one (1) 5.0 mm screw with the Phillips head #000 screwdriver.
  4. Canon PowerShot A540 Front Cover Replacement: paso 4, imagen 1 de 1
    • Turn the camera to the right side of the LCD screen.
    • Remove the three (3) 4.0 mm screws with the Phillips head #000 screwdriver.
  5. Canon PowerShot A540 Front Cover Replacement: paso 5, imagen 1 de 3 Canon PowerShot A540 Front Cover Replacement: paso 5, imagen 2 de 3 Canon PowerShot A540 Front Cover Replacement: paso 5, imagen 3 de 3
    • Gently remove the back cover.
    • Start at the bottom at the corner of the "Card/Batt. Open" Cover.
    • Then move onto the other edges and the top.
    • It may be tight at the top!
  6. Canon PowerShot A540 Front Cover Replacement, Front Cover: paso 6, imagen 1 de 2 Canon PowerShot A540 Front Cover Replacement, Front Cover: paso 6, imagen 2 de 2
    • Turn the camera to view the front.
    • Remove the lens guard.
    • Press the lens guard's button as you turn the guard counterclockwise.
  7. Canon PowerShot A540 Front Cover Replacement: paso 7, imagen 1 de 1
    • Turn the camera to the side left of the LCD screen.
    • Remove the one (1) 4.0 mm screw with the Phillips head #000 screwdriver.
  8. Canon PowerShot A540 Front Cover Replacement: paso 8, imagen 1 de 1
    • Remove the front cover gently.
    • When removing the front cover, a thin, black rubber washer may fall off the lens. If it does, make sure to put it back on the lens before reassembly.
Conclusión
2 personas más completaron esta guía.
Carley Fuller
Miembro Desde 03/23/15
434 Reputación
3 Guías creadas
Equipo
Baylor, Team 7-12, Williams Spring 2015 Miembro de Baylor, Team 7-12, Williams Spring 2015
BU-WILLIAMS-S15S7G12
3 Miembros
20 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 12
Ultimos 30 días: 38
Todo El Tiempo: 1,722
