Saltar al contenido principal
Canon PowerShot A460 Motherboard Replacement
Qué necesitas
  1. Canon PowerShot A460 Motherboard Replacement, Battery: paso 1, imagen 1 de 1
    • Slide the switch on the battery cover labeled "CARD/BATT. OPEN." to the right.
    • While still holding the switch, pull the cover down, allowing it to release and open.
  2. Canon PowerShot A460 Motherboard Replacement: paso 2, imagen 1 de 1
    • Tilt the camera slightly to allow the batteries to fall out.
  3. Canon PowerShot A460 Motherboard Replacement: paso 3, imagen 1 de 1
    • Press on and release the memory card to eject it.
  4. Canon PowerShot A460 Motherboard Replacement, Front Casing: paso 4, imagen 1 de 1
    • Unscrew the 5mm Phillips #00 screw from the bottom of the camera.
    • Make sure to keep the different size screws organized to make reassembling the camera simpler.
  5. Canon PowerShot A460 Motherboard Replacement: paso 5, imagen 1 de 1
    • Unscrew the three 2mm Phillips #00 screws that are located on the bottom of the camera.
  6. Canon PowerShot A460 Motherboard Replacement: paso 6, imagen 1 de 1
    • Remove the 4mm Phillips #00 screw that is located on the left side of the camera, if the display screen is facing you.
  7. Canon PowerShot A460 Motherboard Replacement: paso 7, imagen 1 de 1
    • Take out the 4mm Phillips #00 screw under the rubber flap on the right end of the camera.
  8. Canon PowerShot A460 Motherboard Replacement: paso 8, imagen 1 de 2 Canon PowerShot A460 Motherboard Replacement: paso 8, imagen 2 de 2
    • Remove the second battery cover on the bottom of camera.
    • Take the silver battery out of the camera.
  9. Canon PowerShot A460 Motherboard Replacement: paso 9, imagen 1 de 3 Canon PowerShot A460 Motherboard Replacement: paso 9, imagen 2 de 3 Canon PowerShot A460 Motherboard Replacement: paso 9, imagen 3 de 3
    • Remove the 4mm Phillips #00 screw on the inside of the flap that hides the battery and memory card slots.
    • Remove the light grey, plastic piece.
    • Remove the plastic portion of the battery flap cover. The metal piece will remain attached.
  10. Canon PowerShot A460 Motherboard Replacement: paso 10, imagen 1 de 3 Canon PowerShot A460 Motherboard Replacement: paso 10, imagen 2 de 3 Canon PowerShot A460 Motherboard Replacement: paso 10, imagen 3 de 3
    • Slightly pull on each side of the camera. It should loosen up and come apart.
    • If it does not pull apart right away, use a little more force.
    • Do not give up!
  11. Canon PowerShot A460 Motherboard Replacement, Back Casing: paso 11, imagen 1 de 1
    • Remove the back case of the camera by pulling from the top.
    • Be careful when pulling off the case. There is a delicate gold ribbon connecting the bottom of the camera to the back case.
  12. Canon PowerShot A460 Motherboard Replacement, LCD Screen: paso 12, imagen 1 de 1
    • Remove the 4mm Phillips #00 screw from above the ribbon.
  13. Canon PowerShot A460 Motherboard Replacement: paso 13, imagen 1 de 1
    • Gently peel off the blue tape on the top of the LCD screen.
  14. Canon PowerShot A460 Motherboard Replacement: paso 14, imagen 1 de 1
    • Remove the 4mm Phillips #00 screw previously concealed by the blue tape.
  15. Canon PowerShot A460 Motherboard Replacement: paso 15, imagen 1 de 1
    • Gently lift the LCD screen off of the front casing by pulling up a tab on the side of the camera.
  16. Canon PowerShot A460 Motherboard Replacement: paso 16, imagen 1 de 1
    • Using a spudger, lift the grey tabs to allow the ribbon to slide out.
  17. Canon PowerShot A460 Motherboard Replacement: paso 17, imagen 1 de 1
    • Since the tabs have been lifted, the ribbon should now slide out out easily.
    • Be careful not to distort the ribbon in any way.
  18. Canon PowerShot A460 Motherboard Replacement, Motherboard: paso 18, imagen 1 de 1
    • Remove the 5mm Phillips #00 screw located above the small black piece on the right side of the mother board.
  19. Canon PowerShot A460 Motherboard Replacement: paso 19, imagen 1 de 2 Canon PowerShot A460 Motherboard Replacement: paso 19, imagen 2 de 2
    • Remove the 4mm Phillips #00 screw at the bottom of the black piece.
    • Detach the black piece that the screws previously held in place.
  20. Canon PowerShot A460 Motherboard Replacement: paso 20, imagen 1 de 1
    • Remove the 5mm Phillips #00 screw in the middle of the motherboard.
  21. Canon PowerShot A460 Motherboard Replacement: paso 21, imagen 1 de 1
    • Remove the 5mm Phillips #00 screw that holds the metal piece to the bottom of the camera .
  22. Canon PowerShot A460 Motherboard Replacement: paso 22, imagen 1 de 1
    • Remove the 5mm Phillips #00 screw that is located on the top of camera.
  23. Canon PowerShot A460 Motherboard Replacement: paso 23, imagen 1 de 1
    • Remove the 2mm Phillips #00 screw that is located on the far left of the motherboard.
    • Be careful not to damage the multiple adjacent orange ribbons.
  24. Canon PowerShot A460 Motherboard Replacement: paso 24, imagen 1 de 1
    • Remove the 5mm Phillips #00 screw near the bottom left of the motherboard.
  25. Canon PowerShot A460 Motherboard Replacement: paso 25, imagen 1 de 2 Canon PowerShot A460 Motherboard Replacement: paso 25, imagen 2 de 2
    • Using a spudger, unlock the locking mechanism that holds the lower orange ribbon in place.
    • Once unlocked, slide out the ribbon.
  26. Canon PowerShot A460 Motherboard Replacement: paso 26, imagen 1 de 1
    • Using a spudger, unlock the locking mechanism that holds the upper orange ribbon in place.
  27. Canon PowerShot A460 Motherboard Replacement: paso 27, imagen 1 de 1
    • All that is required is to unsolder the few remaining wires. Then, the motherboard will be ready to be replaced!
Conclusión
2 personas más completaron esta guía.
Tanner Coleman
Miembro Desde 01/18/13
40 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 19-42, Regan Winter 2013 Miembro de Cal Poly, Team 19-42, Regan Winter 2013
CPSU-REGAN-W13S19G42
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 13
Ultimos 30 días: 37
Todo El Tiempo: 1,771
