Saltar al contenido principal
Canon PowerShot A4000 IS SD Card Replacement
Qué necesitas
  1. Canon PowerShot A4000 IS SD Card Replacement, Reinserting Memory Card: paso 1, imagen 1 de 1
    • The inside of your Canon PowerShot A4000 camera should have a picture showing how to reinsert your memory card.
    • Line the memory card up like it is shown in the camera and using your thumb, press down on the card until you hear a click. Your memory card is now back in place and ready for use.
  2. Canon PowerShot A4000 IS SD Card Replacement, Memory Card Removal: paso 2, imagen 1 de 2 Canon PowerShot A4000 IS SD Card Replacement, Memory Card Removal: paso 2, imagen 2 de 2
    • To open the battery compartment where the memory card is stored, refer to the Battery Replacement Guide.
    • The memory card is stored behind the battery on the side opposite of the lens as outlined by the red rectangle in the picture.
    • To remove the memory card, use your thumb to press down on the exposed part of the card.
    • The card will dip down further into the compartment and then you will hear a click as the card is released.
Conclusión
Ansley Gardner
Miembro Desde 10/13/14
761 Reputación
7 Guías creadas
Equipo
Clemson, Team 1-3, Benson Fall 2014 Miembro de Clemson, Team 1-3, Benson Fall 2014
CLEM-BENSON-F14S1G3
3 Miembros
17 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 11
Ultimos 30 días: 11
Todo El Tiempo: 898
