Saltar al contenido principal
Canon PowerShot A3400 IS Plastic Case Replacement
Qué necesitas
  1. Canon PowerShot A3400 IS Plastic Case Replacement, Battery: paso 1, imagen 1 de 1
    • Place thumb on area right next to where it says open and slide to the right to open.
  2. Canon PowerShot A3400 IS Plastic Case Replacement: paso 2, imagen 1 de 1
    • Remove the battery by pushing the orange object outwards; the battery will spring up and out.
  3. Canon PowerShot A3400 IS Plastic Case Replacement, Plastic Case: paso 3, imagen 1 de 2 Canon PowerShot A3400 IS Plastic Case Replacement, Plastic Case: paso 3, imagen 2 de 2
    • Remove the two 5.00 mm screws in the bottom of the casing with a Philips #000 screwdriver
  4. Canon PowerShot A3400 IS Plastic Case Replacement: paso 4, imagen 1 de 2 Canon PowerShot A3400 IS Plastic Case Replacement: paso 4, imagen 2 de 2
    • Place the camera on to the side that has the image stabilizer label.
    • Remove the 5.00 mm screws that are on this side using the screwdriver.
  5. Canon PowerShot A3400 IS Plastic Case Replacement: paso 5, imagen 1 de 1
    • Place camera on to the side with the A/V Out Digital Cover facing up.
    • Remove this visible 5.00 mm screw.
    • Pull the A/V Out Digital cover back to uncover the next step.
  6. Canon PowerShot A3400 IS Plastic Case Replacement: paso 6, imagen 1 de 1
    • Remove the 5.00 mm screw from behind the cover.
  7. Canon PowerShot A3400 IS Plastic Case Replacement: paso 7, imagen 1 de 1
    • Make sure the battery cover is open.
  8. Canon PowerShot A3400 IS Plastic Case Replacement: paso 8, imagen 1 de 2 Canon PowerShot A3400 IS Plastic Case Replacement: paso 8, imagen 2 de 2
    • Turn the camera onto the side with the A/V out Digital cover.
    • Use your finger to pull this tab to the right.
  9. Canon PowerShot A3400 IS Plastic Case Replacement: paso 9, imagen 1 de 3 Canon PowerShot A3400 IS Plastic Case Replacement: paso 9, imagen 2 de 3 Canon PowerShot A3400 IS Plastic Case Replacement: paso 9, imagen 3 de 3
    • Remove the lens side by using your fingers or a spudger to pry it gently open.
    • Try to pry it loose all around that side so that it is easier to pull off.
  10. Canon PowerShot A3400 IS Plastic Case Replacement: paso 10, imagen 1 de 3 Canon PowerShot A3400 IS Plastic Case Replacement: paso 10, imagen 2 de 3 Canon PowerShot A3400 IS Plastic Case Replacement: paso 10, imagen 3 de 3
    • Using your fingers, pull the screen side gently off.
    • Try to loosen it all around that side so that it is easier to try and pull it off.
Conclusión
Una persona más ha completado esta guía.
Equipo
USF Tampa, Team 1-1, Sullivan Winter 2015 Miembro de USF Tampa, Team 1-1, Sullivan Winter 2015
USFT-SULLIVAN-W15S1G1
3 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 3
Ultimos 30 días: 4
Todo El Tiempo: 276
