Saltar al contenido principal
Canon PowerShot A2200 Button Assembly Replacement
Qué necesitas
  1. Canon PowerShot A2200 Button Assembly Replacement, Back Cover: paso 1, imagen 1 de 1
    • First, remove the batteries and memory card.
    • Remove the 5.0 mm black screw with a Phillips #00 screwdriver.
    • Remove the 5.0 mm silver screw with a Phillips #00 screwdriver.
  2. Canon PowerShot A2200 Button Assembly Replacement: paso 2, imagen 1 de 1
    • Remove the 5.0 mm black screw on the right with a Phillips #00 screwdriver.
  3. Canon PowerShot A2200 Button Assembly Replacement: paso 3, imagen 1 de 1
    • Remove the 5.0 mm screw on the left with a Phillips #00 screwdriver.
  4. Canon PowerShot A2200 Button Assembly Replacement: paso 4, imagen 1 de 3 Canon PowerShot A2200 Button Assembly Replacement: paso 4, imagen 2 de 3 Canon PowerShot A2200 Button Assembly Replacement: paso 4, imagen 3 de 3
    • Begin taking off the back cover with a plastic opening tool.
    • Begin by wedging the plastic opening tool behind the bottom left corner of the LCD screen as shown.
    • Slide the plastic opening tool to the right, along the mating edge, to pry off the back cover.
    • Continue taking off the back cover along the left side of the camera as seen in the third picture.
  5. Canon PowerShot A2200 Button Assembly Replacement: paso 5, imagen 1 de 3 Canon PowerShot A2200 Button Assembly Replacement: paso 5, imagen 2 de 3 Canon PowerShot A2200 Button Assembly Replacement: paso 5, imagen 3 de 3
    • Use the plastic opening tool to separate the top section of the back cover from the frame.
    • Once there is enough separation between the back cover and the frame, remove the back cover for replacement.
  6. Canon PowerShot A2200 Button Assembly Replacement, Button Assembly: paso 6, imagen 1 de 2 Canon PowerShot A2200 Button Assembly Replacement, Button Assembly: paso 6, imagen 2 de 2
    • Remove the internal 4.4mm screw with a Phillips 00 screwdriver.
    • Make sure you're removing the screw circled in red, not the screw crossed out in orange.
  7. Canon PowerShot A2200 Button Assembly Replacement: paso 7, imagen 1 de 1
    • Gently lift of the buttons for replacement. They should come off without excessive force.
    • If the buttons do not lift off easily, you may have unscrewed the wrong screw. Revert to previous step.
Conclusión
Una persona más ha completado esta guía.
Benjamin Gee
Miembro Desde 03/31/15
953 Reputación
5 Guías creadas
Equipo
Baylor, Team 4-5, Williams Spring 2015 Miembro de Baylor, Team 4-5, Williams Spring 2015
BU-WILLIAMS-S15S4G5
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 11
Todo El Tiempo: 719
