Saltar al contenido principal
Canon PowerShot A2200 Back Cover Replacement
Qué necesitas
  1. Canon PowerShot A2200 Back Cover Replacement, Back Cover: paso 1, imagen 1 de 1
    • First, remove the batteries and memory card.
    • Remove the 5.0 mm black screw with a Phillips #00 screwdriver.
    • Remove the 5.0 mm silver screw with a Phillips #00 screwdriver.
  2. Canon PowerShot A2200 Back Cover Replacement: paso 2, imagen 1 de 1
    • Remove the 5.0 mm black screw on the right with a Phillips #00 screwdriver.
  3. Canon PowerShot A2200 Back Cover Replacement: paso 3, imagen 1 de 1
    • Remove the 5.0 mm screw on the left with a Phillips #00 screwdriver.
  4. Canon PowerShot A2200 Back Cover Replacement: paso 4, imagen 1 de 3 Canon PowerShot A2200 Back Cover Replacement: paso 4, imagen 2 de 3 Canon PowerShot A2200 Back Cover Replacement: paso 4, imagen 3 de 3
    • Begin taking off the back cover with a plastic opening tool.
    • Begin by wedging the plastic opening tool behind the bottom left corner of the LCD screen as shown.
    • Slide the plastic opening tool to the right, along the mating edge, to pry off the back cover.
    • Continue taking off the back cover along the left side of the camera as seen in the third picture.
  5. Canon PowerShot A2200 Back Cover Replacement: paso 5, imagen 1 de 3 Canon PowerShot A2200 Back Cover Replacement: paso 5, imagen 2 de 3 Canon PowerShot A2200 Back Cover Replacement: paso 5, imagen 3 de 3
    • Use the plastic opening tool to separate the top section of the back cover from the frame.
    • Once there is enough separation between the back cover and the frame, remove the back cover for replacement.
Conclusión
Equipo
Baylor, Team 4-5, Williams Spring 2015 Miembro de Baylor, Team 4-5, Williams Spring 2015
BU-WILLIAMS-S15S4G5
4 Miembros
11 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 16
Todo El Tiempo: 928
