Saltar al contenido principal
Canon PowerShot A200 Batteries Replacement
  1. Canon PowerShot A200 Batteries Replacement, Outer Battery Cover: paso 1, imagen 1 de 2 Canon PowerShot A200 Batteries Replacement, Outer Battery Cover: paso 1, imagen 2 de 2
    • Place the camera so the battery cover is facing up, as shown in the picture.
    • Gently push on the outer battery cover until you hear a click, and then release.
  2. Canon PowerShot A200 Batteries Replacement, Inner Battery Cover: paso 2, imagen 1 de 2 Canon PowerShot A200 Batteries Replacement, Inner Battery Cover: paso 2, imagen 2 de 2
    • To open the inner battery cover, push down on the grey latch until you hear a click, and then release.
    • Remove the dead batteries from the camera.
  3. Canon PowerShot A200 Batteries Replacement, Replacing the Batteries: paso 3, imagen 1 de 1
    • After removing the batteries, insert the new batteries in the proper direction.
    • Now push the black, inner cover down until you hear a click to secure the batteries in place.
    • Push down and forward on the outer cover to secure the latch. Your camera will now be fully charged.
Conclusión
Congratulations, you're done.
Ellen Chambers
Miembro Desde 01/05/11
231 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 7-37, Regan Winter 2011 Miembro de Cal Poly, Team 7-37, Regan Winter 2011
CPSU-REGAN-W11S7G37
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 9
Todo El Tiempo: 2,092
