Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Canon Pixma MP480 Motherboard Replacement
Qué necesitas
  1. Canon Pixma MP480 Motherboard Replacement, Rear and Side Panel: paso 1, imagen 1 de 2 Canon Pixma MP480 Motherboard Replacement, Rear and Side Panel: paso 1, imagen 2 de 2
    • Remove the two 7.9 mm screws using a Phillips #1 screwdriver.
    Pregunta a FixBot
    Agregar Comentario
  2. Canon Pixma MP480 Motherboard Replacement: paso 2, imagen 1 de 1
    • Lift up the back cover to remove it.
    • You may need to lift firmly as it requires quite a bit of force.
    Pregunta a FixBot
    Agregar Comentario
  3. Canon Pixma MP480 Motherboard Replacement: paso 3, imagen 1 de 1
    • Open the front tray.
    Pregunta a FixBot
    Agregar Comentario
  4. Canon Pixma MP480 Motherboard Replacement: paso 4, imagen 1 de 2 Canon Pixma MP480 Motherboard Replacement: paso 4, imagen 2 de 2
    • Open the scanner compartment.
    • Make sure the blue lever locks into place to keep the compartment open.
    Pregunta a FixBot
    Agregar Comentario
  5. Canon Pixma MP480 Motherboard Replacement: paso 5, imagen 1 de 2 Canon Pixma MP480 Motherboard Replacement: paso 5, imagen 2 de 2
    • Remove the blue lever from its slot by pushing it back and twisting clockwise.
    • Close the scanner compartment and cover.
    Pregunta a FixBot
    Agregar Comentario
  6. Canon Pixma MP480 Motherboard Replacement: paso 6, imagen 1 de 2 Canon Pixma MP480 Motherboard Replacement: paso 6, imagen 2 de 2
    • Pry open the side cover with the plastic opening tool.
    Pregunta a FixBot
    Agregar Comentario
  7. Canon Pixma MP480 Motherboard Replacement: paso 7, imagen 1 de 2 Canon Pixma MP480 Motherboard Replacement: paso 7, imagen 2 de 2
    • Flip the printer over so that the bottom of the printer is facing you.
    • Use the plastic opening tool to remove the corner of the side panel from the plastic pin.
    Pregunta a FixBot
    Agregar Comentario
  8. Canon Pixma MP480 Motherboard Replacement: paso 8, imagen 1 de 2 Canon Pixma MP480 Motherboard Replacement: paso 8, imagen 2 de 2
    • Use the plastic opening tool to loosen the side panel from the bottom of the printer.
    Pregunta a FixBot
    Agregar Comentario
  9. Canon Pixma MP480 Motherboard Replacement, Motherboard: paso 9, imagen 1 de 1
    • Gently pull the 6 ribbon wires out.
    • Gently pull the 4 molded cable assemblies out.
    Pregunta a FixBot
    Agregar Comentario
  10. Canon Pixma MP480 Motherboard Replacement: paso 10, imagen 1 de 2 Canon Pixma MP480 Motherboard Replacement: paso 10, imagen 2 de 2
    • Unscrew the five silver Phillips screws that secure the motherboard:
    • Five 3.65mm Phillips #1 screws.
    Pregunta a FixBot
    Agregar Comentario
  11. Canon Pixma MP480 Motherboard Replacement: paso 11, imagen 1 de 2 Canon Pixma MP480 Motherboard Replacement: paso 11, imagen 2 de 2
    • Once all wires and screws have been removed, gently take the motherboard out of the printer.
    • These wires are soldered onto the bottom of the PCB and must be de-soldered in order to completely detach the motherboard from the printer.
    • If you do not know how to operate a soldering iron, do not attempt to finish this guide.
    • De-solder these eight solder joints on the bottom of the motherboard.
    • When reinstalling the motherboard back into the printer, solder the highlighted joints (in orange markers in the second photo) back onto the board.
    Pregunta a FixBot
    Agregar Comentario
Conclusión
Congratulations on successfully removing the motherboard from the printer! To reassemble the motherboard, follow these instructions in reverse order.
3 personas más completaron esta guía.
Equipo
Cal Poly, Team 19-41, Regan Winter 2013 Miembro de Cal Poly, Team 19-41, Regan Winter 2013
CPSU-REGAN-W13S19G41
Miembros de 4
6 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 15
Ultimos 30 días: 59
Todo El Tiempo: 5,739
