Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Canon PIXMA iP3600 AC Adapter Replacement
    1. Canon PIXMA iP3600 AC Adapter Replacement, AC Adapter: paso 1, imagen 1 de 2 Canon PIXMA iP3600 AC Adapter Replacement, AC Adapter: paso 1, imagen 2 de 2
      • It is very important to disconnect your printer from the outlet before attempting replacement. This ensures that there is no power reaching the AC adapter.
      • Remove power cord by disconnecting it from the AC Adapter.
      Pregunta a FixBot
      Agregar Comentario
    2. Canon PIXMA iP3600 AC Adapter Replacement: paso 2, imagen 1 de 2 Canon PIXMA iP3600 AC Adapter Replacement: paso 2, imagen 2 de 2
      • Pinch upper and lower prongs, moving them away from the AC adapter.
      Pregunta a FixBot
      Agregar Comentario
    3. Canon PIXMA iP3600 AC Adapter Replacement: paso 3, imagen 1 de 2 Canon PIXMA iP3600 AC Adapter Replacement: paso 3, imagen 2 de 2
      • The AC adapter will now be loose, and able to come away from the printer.
      • Grasp the AC adapter and pull it toward you to remove it.
      Pregunta a FixBot
      Agregar Comentario
    4. Canon PIXMA iP3600 AC Adapter Replacement: paso 4, imagen 1 de 1
      • Rotate the AC adapter toward you so that the blue cord, with white connector head, is facing you.
      Pregunta a FixBot
      Agregar Comentario
    5. Canon PIXMA iP3600 AC Adapter Replacement: paso 5, imagen 1 de 3 Canon PIXMA iP3600 AC Adapter Replacement: paso 5, imagen 2 de 3 Canon PIXMA iP3600 AC Adapter Replacement: paso 5, imagen 3 de 3
      • Grasp the white connector head that is attached to the end of the blue cord.
      • Disconnect the white connector head by gently pulling it away from the AC adapter.
      • You have successfully removed the AC adapter.
      Pregunta a FixBot
      Agregar Comentario
Conclusión
7 personas más completaron esta guía.
Caitlyn
Miembro Desde 10/07/14
1,223 Reputación
4 Guías creadas
Equipo
USF Tampa, Team 1-3, Leahy Fall 2014 Miembro de USF Tampa, Team 1-3, Leahy Fall 2014
USFT-LEAHY-F14S1G3
Miembros de 3
40 Guías creadas
3Guía Comentarios
Does anybody know the pin-out for these power supplies?
James Rudee - Contestar Compartir
WHERE CAN I BUY AC ADAPTER PIXMA GM 5220 PRINTER ? PLAESE !! my cell 678 899 1187, 770368 0409 w
vincent lieu - Contestar Compartir
Well I’ve just taken the AC Adapter out - I’ll let you know if a the replacement works once I’ve purchased it - Which I am hesitant to buy in case that’s not the problem.
The printer is barely 2 years old and barely used, I shouldn’t be experiencing this problem of the printer not turning on.
Canon you need to get your act together if you would like to stay in business, I’m seeing a lot of comments on this problem over a range of different printer models - Mine is a Pixma iX6860.
rezidraft - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 14
Ultimos 30 días: 63
Todo El Tiempo: 5,981
