Saltar al contenido principal
Canon PIXMA TS3300 Ink Cartridge Replacement
Qué necesitas
  1. Canon PIXMA TS3300 Ink Cartridge Replacement, Ink Cartridge: paso 1, imagen 1 de 2 Canon PIXMA TS3300 Ink Cartridge Replacement, Ink Cartridge: paso 1, imagen 2 de 2
    • Press the power button in the top left corner to turn on the printer.
    • The light next to the button will turn green if the printer is on.
  2. Canon PIXMA TS3300 Ink Cartridge Replacement: paso 2, imagen 1 de 2 Canon PIXMA TS3300 Ink Cartridge Replacement: paso 2, imagen 2 de 2
    • Lift the cartridge compartment located in the front of the printer to gain access on the inside of the printer.
    • Allow for the cartridge holder to move into view.
  3. Canon PIXMA TS3300 Ink Cartridge Replacement: paso 3, imagen 1 de 2 Canon PIXMA TS3300 Ink Cartridge Replacement: paso 3, imagen 2 de 2
    • The cartridge should be located in the center of the printer.
    • Push down on the cartridge and pull it out.
  4. Canon PIXMA TS3300 Ink Cartridge Replacement: paso 4, imagen 1 de 2 Canon PIXMA TS3300 Ink Cartridge Replacement: paso 4, imagen 2 de 2
    • Prepare the new cartridge by peeling off the cover.
  5. Canon PIXMA TS3300 Ink Cartridge Replacement: paso 5, imagen 1 de 3 Canon PIXMA TS3300 Ink Cartridge Replacement: paso 5, imagen 2 de 3 Canon PIXMA TS3300 Ink Cartridge Replacement: paso 5, imagen 3 de 3
    • Peel off the orange sticker on the left side of the cartridge.
  6. Canon PIXMA TS3300 Ink Cartridge Replacement: paso 6, imagen 1 de 2 Canon PIXMA TS3300 Ink Cartridge Replacement: paso 6, imagen 2 de 2
    • Insert the cartridge at an angle to the cartridge holder.
    • Push upward on the cartridge until a clicking sound is heard.
  7. Canon PIXMA TS3300 Ink Cartridge Replacement: paso 7, imagen 1 de 1
    • Close the cartridge compartment cover.
    • The printer should make a sound from the cartridges going back to their resting position.
Conclusión
Allow for the cartridge holder to reposition and you are ready to print!
5 personas más completaron esta guía.
2 comentarios
Hi if I replace the ink cartridge with a refill the printer has an error message E16 which I know means cartridge is out of ink. How do I override this message to keep printing. I have a Canon TS3360. Jenny.
Jenny - Contestar
My Pixma TS3300 printer is giving an error message E14 since I replaced the empty cartridges with new 245XL and 246XL cartridges. These should be compatible but aren't working. Please help!
Susan Gardner - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 14
Ultimos 7 días: 71
Ultimos 30 días: 264
Todo El Tiempo: 17,861
