Introducción
The Canon PIXMA MP620B is an all-in-one inkjet printer with an LCD screen, wireless network connectivity support, and high print resolution. Although it has wireless network connectivity, connecting via USB is sometimes the better option for a faster and more secure connection. If you're experiencing issues with the USB connection, such as a weak or non-existent connection, it could be time to replace the Canon printer's USB reader.
Qué necesitas
Locate the tabs on the top of the panel that hook down and into the black side panel.
Insert the Spudger in-between the black panel and the blue panel as shown and pull the two pieces apart.
Remove the two screws from the back right black panel using the Phillips #00 screwdriver.
There is a tab you will have to push down to remove the part.
Once the tab is released, gently lift the cover away from the rest of the device to disengage the clips.
After unclipping all the hooks, pull off the black side panel to reveal the inner circuit boards.
Remove the two screws from the USB reader using the Phillips #00 screwdriver.
Disconnect the large white ribbon cable that leads to the USB reader. As you are pulling out the USB reader, carefully detach the ribbon.
4 personas más completaron esta guía.
