Saltar al contenido principal
Canon PIXMA MP620B Command Screen Replacement
Qué necesitas
  1. Canon PIXMA MP620B Command Screen Replacement, Open Printer Lid: paso 1, imagen 1 de 1
    • Open top lid of the printer to reveal the scanner
  2. Canon PIXMA MP620B Command Screen Replacement, Pull apart the two large lid plates: paso 2, imagen 1 de 2 Canon PIXMA MP620B Command Screen Replacement, Pull apart the two large lid plates: paso 2, imagen 2 de 2
    • Insert the spudger tool into the top lid in between the blue and the black panels.
    • Use this tool to pry the two panels apart
  3. Canon PIXMA MP620B Command Screen Replacement, Take apart the two sections: paso 3, imagen 1 de 1
    • After these two panels are separated, set the top panel to the side for now
  4. Canon PIXMA MP620B Command Screen Replacement, Pull out wires leading to screen assembly: paso 4, imagen 1 de 1
    • Unplug the two wires shown at the right of the command screen
  5. Canon PIXMA MP620B Command Screen Replacement, Unscrew screen assembly: paso 5, imagen 1 de 1
    • Unscrew the four screws shown to detach the command screen from the printer
  6. Canon PIXMA MP620B Command Screen Replacement, Replace assembly: paso 6, imagen 1 de 1
    • Take the detached command screen off of the printer and replace.
Conclusión
4 personas más completaron esta guía.
Equipo
Cal Poly, Team 6-21, Maness Fall 2014 Miembro de Cal Poly, Team 6-21, Maness Fall 2014
CPSU-MANESS-F14S6G21
Miembros de 4
10 Guías creadas
2Guía Comentarios
Ideas as to where to buy replacement screen assembly?
davepi49 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 21
Todo El Tiempo: 1,624
