Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Canon PIXMA MP190 Ink Cartridge Replacement
    1. Canon PIXMA MP190 Ink Cartridge  Replacement, Turn printer on.: paso 1, imagen 1 de 1
      • The printer needs to be on in order to change the ink cartridges.
      Pregunta a FixBot
      Agregar Comentario
    2. Canon PIXMA MP190 Ink Cartridge  Replacement, Locate Ink Cartridges: paso 2, imagen 1 de 3 Canon PIXMA MP190 Ink Cartridge  Replacement, Locate Ink Cartridges: paso 2, imagen 2 de 3 Canon PIXMA MP190 Ink Cartridge  Replacement, Locate Ink Cartridges: paso 2, imagen 3 de 3
      • To locate the ink cartridges the paper output tray must be in the lowered position.
      • Next lift the scanning unit until the scanning support is vertical.
      • Lower the scanning unit until the scanning unit support seats in the scanning unit support slot.
      Pregunta a FixBot
      Agregar Comentario
    3. Canon PIXMA MP190 Ink Cartridge  Replacement, Remove Ink Cartridge: paso 3, imagen 1 de 3 Canon PIXMA MP190 Ink Cartridge  Replacement, Remove Ink Cartridge: paso 3, imagen 2 de 3 Canon PIXMA MP190 Ink Cartridge  Replacement, Remove Ink Cartridge: paso 3, imagen 3 de 3
      • Allow the printer to position the ink cartridge carrier into the ink cartridge removal location.
      • Before replacing the ink cartridge ensure the correct ink cartridge is installed.
      • Push down on the front edge of the ink cartridge.
      • Observe the angle at which the ink cartridge is removed.
      • Grasp ink cartridge and pull up and out to remove.
      Pregunta a FixBot
      Agregar Comentario
Conclusión
4 personas más completaron esta guía.
Equipo
Michigan Tech, Team 1-5, Lauer Fall 2014 Miembro de Michigan Tech, Team 1-5, Lauer Fall 2014
MTU-LAUER-F14S1G5
Miembros de 3
60 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 23
Ultimos 30 días: 57
Todo El Tiempo: 10,473
