Saltar al contenido principal
Canon PIXMA MP190 Ink Cartridge Replacement
  1. Canon PIXMA MP190 Ink Cartridge  Replacement, Turn printer on.: paso 1, imagen 1 de 1
    • The printer needs to be on in order to change the ink cartridges.
  2. Canon PIXMA MP190 Ink Cartridge  Replacement, Locate Ink Cartridges: paso 2, imagen 1 de 3 Canon PIXMA MP190 Ink Cartridge  Replacement, Locate Ink Cartridges: paso 2, imagen 2 de 3 Canon PIXMA MP190 Ink Cartridge  Replacement, Locate Ink Cartridges: paso 2, imagen 3 de 3
    • To locate the ink cartridges the paper output tray must be in the lowered position.
    • Next lift the scanning unit until the scanning support is vertical.
    • Lower the scanning unit until the scanning unit support seats in the scanning unit support slot.
  3. Canon PIXMA MP190 Ink Cartridge  Replacement, Remove Ink Cartridge: paso 3, imagen 1 de 3 Canon PIXMA MP190 Ink Cartridge  Replacement, Remove Ink Cartridge: paso 3, imagen 2 de 3 Canon PIXMA MP190 Ink Cartridge  Replacement, Remove Ink Cartridge: paso 3, imagen 3 de 3
    • Allow the printer to position the ink cartridge carrier into the ink cartridge removal location.
    • Before replacing the ink cartridge ensure the correct ink cartridge is installed.
    • Push down on the front edge of the ink cartridge.
    • Observe the angle at which the ink cartridge is removed.
    • Grasp ink cartridge and pull up and out to remove.
Conclusión
4 personas más completaron esta guía.
Equipo
Michigan Tech, Team 1-5, Lauer Fall 2014 Miembro de Michigan Tech, Team 1-5, Lauer Fall 2014
MTU-LAUER-F14S1G5
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 18
Todo El Tiempo: 9,616
