Saltar al contenido principal
Canon Optura 100MC Hand Strap Replacement
Qué necesitas
  1. Canon Optura 100MC Hand Strap Replacement, Hand Strap: paso 1, imagen 1 de 1
    • Orient the camera with the hand strap facing you.
    • Remove the two 4mm #00 Philips screws.
    • When the screws are removed, the black plate will easily come off as well as the two metal plates under it. Be careful to not let them fall or get lost.
  2. Canon Optura 100MC Hand Strap Replacement: paso 2, imagen 1 de 1
    • Lift the strap up.
Conclusión
Equipo
Cal Poly, Team 1-12, Amido Winter 2011 Miembro de Cal Poly, Team 1-12, Amido Winter 2011
CPSU-AMIDO-W11S1G12
4 Miembros
11 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 9
Ultimos 30 días: 12
Todo El Tiempo: 1,111
