Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Canon ImageCLASS MF4350d Transformer Replacement
Qué necesitas
  1. Canon ImageCLASS MF4350d Transformer Replacement, Front Paneling: paso 1, imagen 1 de 1
    • Lift the printer lid up as shown in the photo.
  2. Canon ImageCLASS MF4350d Transformer Replacement: paso 2, imagen 1 de 2 Canon ImageCLASS MF4350d Transformer Replacement: paso 2, imagen 2 de 2
    • Locate and remove the two 10mm side screws. There is one on each side.
  3. Canon ImageCLASS MF4350d Transformer Replacement: paso 3, imagen 1 de 2 Canon ImageCLASS MF4350d Transformer Replacement: paso 3, imagen 2 de 2
    • Unhook the plastic panel from the printer starting from the top.
    • You may need to wiggle the panel a bit to loosen it.
    • To remove the bottom part of the paneling gently lay the printer on its back.
    • The scanner lid needs to be supported when moving the printer
  4. Canon ImageCLASS MF4350d Transformer Replacement, Right Side Paneling: paso 4, imagen 1 de 3 Canon ImageCLASS MF4350d Transformer Replacement, Right Side Paneling: paso 4, imagen 2 de 3 Canon ImageCLASS MF4350d Transformer Replacement, Right Side Paneling: paso 4, imagen 3 de 3
    • Gently unhook the right side paneling (as looking at the printer's front face) from the printer.
    • Use a gentle back and forth motion to wiggle the hooks out.
  5. Canon ImageCLASS MF4350d Transformer Replacement, Transformer: paso 5, imagen 1 de 2 Canon ImageCLASS MF4350d Transformer Replacement, Transformer: paso 5, imagen 2 de 2
    • Locate the yellow wire connected to the metal box.
    • Carefully pull the yellow wire from the black connector.
    • Wires may detach completely from plug so tug very gently.
  6. Canon ImageCLASS MF4350d Transformer Replacement: paso 6, imagen 1 de 2 Canon ImageCLASS MF4350d Transformer Replacement: paso 6, imagen 2 de 2
    • Locate the spring.
    • Unhook the spring on the side of the metal box.
  7. Canon ImageCLASS MF4350d Transformer Replacement: paso 7, imagen 1 de 1
    • Unscrew the 10mm screw attaching the metal plate to the printer.
  8. Canon ImageCLASS MF4350d Transformer Replacement: paso 8, imagen 1 de 1
    • Lift the transformer out of the printer.
Conclusión
Una persona más ha completado esta guía.
Helena Yanez
Miembro Desde 09/29/13
461 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 13-1, Forte Fall 2013 Miembro de Cal Poly, Team 13-1, Forte Fall 2013
CPSU-FORTE-F13S13G1
Miembros de 5
16 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 16
Ultimos 30 días: 77
Todo El Tiempo: 3,397
