Saltar al contenido principal
Canon ImageCLASS MF4350d Scanner Disassembly
Qué necesitas
  1. Canon ImageCLASS MF4350d Scanner Disassembly, Scanner Disassembly: paso 1, imagen 1 de 1
    • If at any point you see glass that seems cracked or broken, handle with care. Broken glass is sharp and can cause serious damage.
    • Lift up the lid. Then be sure to examine the glass. If there are any cracks or broken fragments handle with extreme care.
  2. Canon ImageCLASS MF4350d Scanner Disassembly: paso 2, imagen 1 de 3 Canon ImageCLASS MF4350d Scanner Disassembly: paso 2, imagen 2 de 3 Canon ImageCLASS MF4350d Scanner Disassembly: paso 2, imagen 3 de 3
    • Locate the black and white hinges.
    • Gently lift out the black and white hinges.
  3. Canon ImageCLASS MF4350d Scanner Disassembly: paso 3, imagen 1 de 3 Canon ImageCLASS MF4350d Scanner Disassembly: paso 3, imagen 2 de 3 Canon ImageCLASS MF4350d Scanner Disassembly: paso 3, imagen 3 de 3
    • Next, locate and remove the four 10mm screws.
  4. Canon ImageCLASS MF4350d Scanner Disassembly: paso 4, imagen 1 de 1
    • Gently, pry off the top plate, starting from the back of the printer.
  5. Canon ImageCLASS MF4350d Scanner Disassembly: paso 5, imagen 1 de 2 Canon ImageCLASS MF4350d Scanner Disassembly: paso 5, imagen 2 de 2
    • After you have taken off the plate, check to make sure that there is no broken glass. If there is broken glass handle it with gloves. Broken glass, if handled improperly, can cause physical injury.
Conclusión
5 personas más completaron esta guía.
Equipo
Cal Poly, Team 13-1, Forte Fall 2013 Miembro de Cal Poly, Team 13-1, Forte Fall 2013
CPSU-FORTE-F13S13G1
5 Miembros
16 Guías creadas
Un comentario
The paper tore and is now not visible. How do I remove the printer's components to access the paper deep in the machine? Is there a method to factory reset the machine? Can I somehow make the rollers rotate to attempt to pushing the paper out?
Kyle - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 9
Ultimos 30 días: 26
Todo El Tiempo: 4,962
