Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Canon ImageCLASS MF4350d Replace Scanner Glass Replacement
Qué necesitas
  1. Canon ImageCLASS MF4350d Replace Scanner Glass Replacement, Scanner Disassembly: paso 1, imagen 1 de 1
    • If at any point you see glass that seems cracked or broken, handle with care. Broken glass is sharp and can cause serious damage.
    • Lift up the lid. Then be sure to examine the glass. If there are any cracks or broken fragments handle with extreme care.
  2. Canon ImageCLASS MF4350d Replace Scanner Glass Replacement: paso 2, imagen 1 de 3 Canon ImageCLASS MF4350d Replace Scanner Glass Replacement: paso 2, imagen 2 de 3 Canon ImageCLASS MF4350d Replace Scanner Glass Replacement: paso 2, imagen 3 de 3
    • Locate the black and white hinges.
    • Gently lift out the black and white hinges.
  3. Canon ImageCLASS MF4350d Replace Scanner Glass Replacement: paso 3, imagen 1 de 3 Canon ImageCLASS MF4350d Replace Scanner Glass Replacement: paso 3, imagen 2 de 3 Canon ImageCLASS MF4350d Replace Scanner Glass Replacement: paso 3, imagen 3 de 3
    • Next, locate and remove the four 10mm screws.
  4. Canon ImageCLASS MF4350d Replace Scanner Glass Replacement: paso 4, imagen 1 de 1
    • Gently, pry off the top plate, starting from the back of the printer.
  5. Canon ImageCLASS MF4350d Replace Scanner Glass Replacement: paso 5, imagen 1 de 2 Canon ImageCLASS MF4350d Replace Scanner Glass Replacement: paso 5, imagen 2 de 2
    • After you have taken off the plate, check to make sure that there is no broken glass. If there is broken glass handle it with gloves. Broken glass, if handled improperly, can cause physical injury.
  6. Canon ImageCLASS MF4350d Replace Scanner Glass Replacement, Replace Scanner Glass: paso 6, imagen 1 de 1
    • Take out the damaged glass and fit the replacement glass to the printer according to the picture.
Conclusión
4 personas más completaron esta guía.
Equipo
Cal Poly, Team 13-1, Forte Fall 2013 Miembro de Cal Poly, Team 13-1, Forte Fall 2013
CPSU-FORTE-F13S13G1
Miembros de 5
16 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 8
Ultimos 7 días: 32
Ultimos 30 días: 110
Todo El Tiempo: 10,229
