Saltar al contenido principal
Canon FS30 LCD Screen Replacement
Qué necesitas
  1. Canon FS30 LCD Screen Replacement, LCD Screen: paso 1, imagen 1 de 2 Canon FS30 LCD Screen Replacement, LCD Screen: paso 1, imagen 2 de 2
    • Locate battery compartment cover. Turn the device over and locate the battery compartment cover.
    • Place a finger or thumb on the textured section of the battery compartment cover and push forward until you hear a click. Then lift the battery compartment cover.
  2. Canon FS30 LCD Screen Replacement: paso 2, imagen 1 de 2 Canon FS30 LCD Screen Replacement: paso 2, imagen 2 de 2
    • Locate the grey latch and move it aside. The battery is spring loaded and will pop up.
    • Remove the battery.
  3. Canon FS30 LCD Screen Replacement: paso 3, imagen 1 de 2 Canon FS30 LCD Screen Replacement: paso 3, imagen 2 de 2
    • Using the Phillips #000, remove the two screws on the LCD panel.
    • Using the Phillips #000, remove two more screws near the LCD panel swivel point.
  4. Canon FS30 LCD Screen Replacement: paso 4, imagen 1 de 2 Canon FS30 LCD Screen Replacement: paso 4, imagen 2 de 2
    • Use the plastic opening tool to remove the plastic cover from the LCD panel.
  5. Canon FS30 LCD Screen Replacement: paso 5, imagen 1 de 2 Canon FS30 LCD Screen Replacement: paso 5, imagen 2 de 2
    • Locate and remove two screws on the logic board.
    • Use the plastic opening tool to open the ZIF (zero insertion force) connector. The LCD ribbon should pop up.
  6. Canon FS30 LCD Screen Replacement: paso 6, imagen 1 de 2 Canon FS30 LCD Screen Replacement: paso 6, imagen 2 de 2
    • Locate the LCD screen underneath the logic board and slide it out.
Conclusión
Una persona más ha completado esta guía.
Emanuel Keller
Miembro Desde 02/28/17
419 Reputación
4 Guías creadas
Equipo
USF Tampa, Team S1-G4, Nance Spring 2017 Miembro de USF Tampa, Team S1-G4, Nance Spring 2017
USFT-NANCE-S17S1G4
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 14
Todo El Tiempo: 335
