Saltar al contenido principal
Canon EOS Rebel XSi LCD Screen Replacement
Qué necesitas
  1. Canon EOS Rebel XSi LCD Screen Replacement, Back Panel: paso 1, imagen 1 de 1
    • Squeeze the eyepiece between your index finger and thumb and lift up and off.
  2. Canon EOS Rebel XSi LCD Screen Replacement: paso 2, imagen 1 de 1
    • Using the PH000 screwdriver head, remove the four 4 mm screws on the bottom of the camera.
  3. Canon EOS Rebel XSi LCD Screen Replacement: paso 3, imagen 1 de 1
    • Using the PH000 screwdriver head, remove the two 3mm screws on the right side of the camera (from the LCD screen).
  4. Canon EOS Rebel XSi LCD Screen Replacement: paso 4, imagen 1 de 1
    • Remove grip by slowly peeling off.
  5. Canon EOS Rebel XSi LCD Screen Replacement: paso 5, imagen 1 de 1
    • Using the PH000 screwdriver, remove the four 4mm screws behind the eyepiece.
  6. Canon EOS Rebel XSi LCD Screen Replacement: paso 6, imagen 1 de 1
    • Using the PH000 screwdriver head, remove one 4 mm screw on the left side of the camera (from the LCD screen).
  7. Canon EOS Rebel XSi LCD Screen Replacement: paso 7, imagen 1 de 1
    • Remove the side panel by lifting off with fingers.
  8. Canon EOS Rebel XSi LCD Screen Replacement: paso 8, imagen 1 de 1
    • Use hands to pry off the back panel.
  9. Canon EOS Rebel XSi LCD Screen Replacement, LCD Screen: paso 9, imagen 1 de 1
    • Using the PH00 screwdriver head, unscrew four 4 mm screws and one 2 mm screw
  10. Canon EOS Rebel XSi LCD Screen Replacement: paso 10, imagen 1 de 2 Canon EOS Rebel XSi LCD Screen Replacement: paso 10, imagen 2 de 2
    • Remove the metal plate covering inside of the LCD screen
  11. Canon EOS Rebel XSi LCD Screen Replacement: paso 11, imagen 1 de 1
    • Carefully disconnect the circuitry sheets from the white plastic bases
  12. Canon EOS Rebel XSi LCD Screen Replacement: paso 12, imagen 1 de 2 Canon EOS Rebel XSi LCD Screen Replacement: paso 12, imagen 2 de 2
    • Using the plastic spudger, carefully pry out the LCD screen from the back panel
Conclusión
Erik Mork
Miembro Desde 01/27/17
602 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 22-10, Maness Winter 2017 Miembro de Cal Poly, Team 22-10, Maness Winter 2017
CPSU-MANESS-W17S22G10
Miembros de 4
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 9
Ultimos 30 días: 33
Todo El Tiempo: 1,914
