Saltar al contenido principal
Canon EOS Rebel XS 35mm Lens Replacement
Qué necesitas
  1. Canon EOS Rebel XS 35mm Lens Replacement, Top Cover: paso 1, imagen 1 de 2 Canon EOS Rebel XS 35mm Lens Replacement, Top Cover: paso 1, imagen 2 de 2
    • Using a PH000 screwdriver bit, remove the three black screws shown in the two pictures that are all 4 mm in length and 1 mm in diameter.
  2. Canon EOS Rebel XS 35mm Lens Replacement: paso 2, imagen 1 de 1
    • Using a Phillips #000 screwdriver, remove the two black screws shown in the picture that are both 6 mm in length and 1.25 mm in diameter.
  3. Canon EOS Rebel XS 35mm Lens Replacement: paso 3, imagen 1 de 1
    • Pull off the front cover.
  4. Canon EOS Rebel XS 35mm Lens Replacement: paso 4, imagen 1 de 3 Canon EOS Rebel XS 35mm Lens Replacement: paso 4, imagen 2 de 3 Canon EOS Rebel XS 35mm Lens Replacement: paso 4, imagen 3 de 3
    • Using an opening tool (you can also use your nails, but try not to use something potentially damaging to the camera such as metal), separate the top cover from the rest of the camera!
  5. Canon EOS Rebel XS 35mm Lens Replacement, Lens: paso 5, imagen 1 de 1
    • Using a PH000 screwdriver bit, remove the 2 black screws circled in the picture, which are both 8 mm in length and 1.5 mm in diameter.
  6. Canon EOS Rebel XS 35mm Lens Replacement: paso 6, imagen 1 de 1
    • Using your fingers, remove the lens!
Conclusión
christiansvezia
Miembro Desde 10/24/18
1,108 Reputación
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 8
Todo El Tiempo: 324
