Saltar al contenido principal
Canon EOS Rebel XS 35mm Lens Mount Parts Replacement
Qué necesitas
  1. Canon EOS Rebel XS 35mm Lens Mount Parts Replacement, Lens Mount Parts: paso 1, imagen 1 de 1
    • Using a PH000 screwdriver bit, remove the 2 black screws circled in the picture, which are both 6 mm in length and 1.25 mm in diameter.
  2. Canon EOS Rebel XS 35mm Lens Mount Parts Replacement: paso 2, imagen 1 de 1
    • Using a PH000 screwdriver bit, remove the 5 black screws circled in the picture, which are all 5.5 mm in length and 2 mm in diameter.
  3. Canon EOS Rebel XS 35mm Lens Mount Parts Replacement: paso 3, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Simply using your fingers - although you can use something else such as tweezers - remove the first layer of the lens mount. This first layer is black, plastic, has a red dot at the top, and so on.
  4. Canon EOS Rebel XS 35mm Lens Mount Parts Replacement: paso 4, imagen 1 de 1
    • Using (preferably) tweezers - although you can also use your fingers - remove the flimsy brass-colored layer of the lens mount.
  5. Canon EOS Rebel XS 35mm Lens Mount Parts Replacement: paso 5, imagen 1 de 1
    • Using (preferably) tweezers - although you can also use your fingers - remove the silver layer of the lens mount.
Conclusión
Reassembly can be a lot harder than disassembly for this part of the camera, which accounts for the large range in estimated time.
christiansvezia
Miembro Desde 10/24/18
1,108 Reputación
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 17
Todo El Tiempo: 413
