Saltar al contenido principal
Canon EOS Rebel XS 35mm Camera Mode Dial Replacement
Qué necesitas
  1. Canon EOS Rebel XS 35mm Camera Mode Dial Replacement, Top Cover: paso 1, imagen 1 de 2 Canon EOS Rebel XS 35mm Camera Mode Dial Replacement, Top Cover: paso 1, imagen 2 de 2
    • Using a PH000 screwdriver bit, remove the three black screws shown in the two pictures that are all 4 mm in length and 1 mm in diameter.
  2. Canon EOS Rebel XS 35mm Camera Mode Dial Replacement: paso 2, imagen 1 de 1
    • Using a Phillips #000 screwdriver, remove the two black screws shown in the picture that are both 6 mm in length and 1.25 mm in diameter.
  3. Canon EOS Rebel XS 35mm Camera Mode Dial Replacement: paso 3, imagen 1 de 1
    • Pull off the front cover.
  4. Canon EOS Rebel XS 35mm Camera Mode Dial Replacement: paso 4, imagen 1 de 3 Canon EOS Rebel XS 35mm Camera Mode Dial Replacement: paso 4, imagen 2 de 3 Canon EOS Rebel XS 35mm Camera Mode Dial Replacement: paso 4, imagen 3 de 3
    • Using an opening tool (you can also use your nails, but try not to use something potentially damaging to the camera such as metal), separate the top cover from the rest of the camera!
  5. Canon EOS Rebel XS 35mm Camera Mode Dial Replacement, Camera Mode Dial: paso 5, imagen 1 de 1
    • Locate the camera dial (surrounded by a red square) and turn the top cover of the camera upside down for access to the screw underneath the dial.
  6. Canon EOS Rebel XS 35mm Camera Mode Dial Replacement: paso 6, imagen 1 de 1
    • Using a PH000 screwdriver bit, remove the silver screw circled in the picture, which is 3 mm in length and 1 mm in diameter.
  7. Canon EOS Rebel XS 35mm Camera Mode Dial Replacement: paso 7, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Using tweezers, remove the metal part surrounded by the red square.
  8. Canon EOS Rebel XS 35mm Camera Mode Dial Replacement: paso 8, imagen 1 de 1
    • Using your fingers, remove the black dial! (The dial is surrounded by a red square in the picture.)
Conclusión
christiansvezia
Miembro Desde 10/24/18
1,108 Reputación
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 15
Ultimos 30 días: 59
Todo El Tiempo: 2,062
