Saltar al contenido principal
Canon EOS Rebel XS 35mm Bottom Cover Replacement
Qué necesitas
  1. Canon EOS Rebel XS 35mm Bottom Cover Replacement, Bottom Cover: paso 1, imagen 1 de 1
    • Remove 6 screws using a PH000 Screwdriver.
    • Remove 1 (7mm) screw
    • Remove 5 (4mm) screws
  2. Canon EOS Rebel XS 35mm Bottom Cover Replacement: paso 2, imagen 1 de 1
    • With your fingers, push on the bottom cover with a horizontal force until it clicks and separates.
  3. Canon EOS Rebel XS 35mm Bottom Cover Replacement: paso 3, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • With tweezers - although you can also use your fingers - you may remove these 5 gears (shown with colored squares around them) and place them somewhere else for the time being. They fall out easily while you're working, so this will help you stay organized.
Conclusión
christiansvezia
Miembro Desde 10/24/18
1,108 Reputación
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 7
Todo El Tiempo: 220
