Saltar al contenido principal
Canon EOS Rebel T6i LCD Display Replacement
Qué necesitas
    • Remove battery and ground your wrist using a grounding strap to prevent damage to device.
  1. Canon EOS Rebel T6i LCD Display Replacement: paso 2, imagen 1 de 1
    • 2 screws on the side -1.3 mm
  2. Canon EOS Rebel T6i LCD Display Replacement: paso 3, imagen 1 de 2 Canon EOS Rebel T6i LCD Display Replacement: paso 3, imagen 2 de 2
    • 4 screws are located on the opposite/interior side of screen case. Use the J000 gauge screw driver head to remove these 4 screws. Furthermore, these screws are a larger gauge then the other 2. Please sort these accordingly.
    • 4 small screws on back 1.58 mm
  3. Canon EOS Rebel T6i LCD Display Replacement: paso 4, imagen 1 de 2 Canon EOS Rebel T6i LCD Display Replacement: paso 4, imagen 2 de 2
    • Following the removal of the 6 screws, Locate the joint of the casing. Place a flat lever inside this crevice and apply pressure. The case should simply pop open into the 2 casing pieces and the screen mechanism. Warning. No Dot try to remove bottom casing until next step.
  4. Canon EOS Rebel T6i LCD Display Replacement: paso 5, imagen 1 de 3 Canon EOS Rebel T6i LCD Display Replacement: paso 5, imagen 2 de 3 Canon EOS Rebel T6i LCD Display Replacement: paso 5, imagen 3 de 3
    • There are several components inside the casing. A board, a power cable, the screen and a ribbon cable. First, using tweezers lift the metallic clamp connecting the ribbon to the board.
    • WARNING. If the lever doesn't lift immediately, do not forcefully lift it. This could damage the ribbon and board. When reapplying the ribbon, secure connection.
  5. Canon EOS Rebel T6i LCD Display Replacement: paso 6, imagen 1 de 1
    • Now that the ribbon is disconnected, remove the board carefully and place it aside. This piece still works so leave it attached to camera.
  6. Canon EOS Rebel T6i LCD Display Replacement: paso 7, imagen 1 de 2 Canon EOS Rebel T6i LCD Display Replacement: paso 7, imagen 2 de 2
    • The screen is glued into the casing. Remove the screen by carefulyl lifting along the edges of the case until the screen pops out. Place new screen into the existing casing. A small about of glue or adhesive may be necessary if their isn't sufficient adhesive remaining in the case. Repeat steps in reverse to reapply screen.
  7. Canon EOS Rebel T6i LCD Display Replacement: paso 8, imagen 1 de 1
    • If screen doesn't power on after replacing the battery, Go back and check connections of the ribbon.
Conclusión
Una persona más ha completado esta guía.
3 comentarios
Very simple and great guide for. See the Canon T6i Bundle
Deve Lee - Contestar
Thanks for this awesome guide its really useful for me. see the Canon 80D Bundle
9 Product Reviews - Contestar
y las refacciones donde?
cafeplazay - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 12
Ultimos 30 días: 31
Todo El Tiempo: 3,949
