Saltar al contenido principal
Canon EOS Rebel T5 SD Card Replacement
Qué necesitas
  1. Canon EOS Rebel T5 SD Card Replacement, Battery: paso 1, imagen 1 de 1
    • Lay the camera on its back so that the card/battery door is facing you.
    • Using your fingernail, slide the tab on the battery door up to release the battery door latch.
  2. Canon EOS Rebel T5 SD Card Replacement: paso 2, imagen 1 de 1
    • Lift the now free card/battery door to reveal the battery compartment.
    • Push the gray lever to the right side so that the battery can be removed and replaced with a new one.
  3. Canon EOS Rebel T5 SD Card Replacement, SD Card: paso 3, imagen 1 de 1
  4. Canon EOS Rebel T5 SD Card Replacement: paso 4, imagen 1 de 1
    • Open the battery compartment by lifting the card/battery door. You will see a thin SD Card slot below the battery.
    • Push in the old SD card until it clicks to remove it and then push in the new card until it clicks into place.
Conclusión
3 personas más completaron esta guía.
Austin Tucker
Miembro Desde 08/27/15
1,036 Reputación
4 Guías creadas
Equipo
USF Tampa, Team 16-4, Wollert Fall 2015 Miembro de USF Tampa, Team 16-4, Wollert Fall 2015
USFT-WOLLERT-F15S16G4
4 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 9
Ultimos 30 días: 33
Todo El Tiempo: 3,330
