Saltar al contenido principal
Canon EOS Rebel T5 Motherboard Replacement
Qué necesitas
  1. Canon EOS Rebel T5 Motherboard Replacement, Battery: paso 1, imagen 1 de 1
    • Lay the camera on its back so that the card/battery door is facing you.
    • Using your fingernail, slide the tab on the battery door up to release the battery door latch.
  2. Canon EOS Rebel T5 Motherboard Replacement: paso 2, imagen 1 de 1
    • Lift the now free card/battery door to reveal the battery compartment.
    • Push the gray lever to the right side so that the battery can be removed and replaced with a new one.
  3. Canon EOS Rebel T5 Motherboard Replacement, Back Panel: paso 3, imagen 1 de 1
    • Turn the camera so that the back is facing to your right.
    • Remove the 5mm Phillips #000 screw above the rubber USB port cover.
  4. Canon EOS Rebel T5 Motherboard Replacement: paso 4, imagen 1 de 1
    • Remove the rubber piece.
    • Unscrew the two screws under the rubber cover to completely remove the rubber cover piece.
    • It is held in place by a notched tether, but can be easily manipulated to slide out.
  5. Canon EOS Rebel T5 Motherboard Replacement: paso 5, imagen 1 de 1
    • Turn your camera so that the bottom is facing you.
    • Remove the 5mm Phillips #000 screws.
  6. Canon EOS Rebel T5 Motherboard Replacement: paso 6, imagen 1 de 1
    • Now turn the camera so that the front is facing towards your right.
    • Remove the two remaining 5mm Phillips #000 screws.
  7. Canon EOS Rebel T5 Motherboard Replacement: paso 7, imagen 1 de 3 Canon EOS Rebel T5 Motherboard Replacement: paso 7, imagen 2 de 3 Canon EOS Rebel T5 Motherboard Replacement: paso 7, imagen 3 de 3
    • Now that all of the exterior screws have been removed, grip the camera firmly on both sides.
    • Gently pry the back panel from the main body of the camera.
    • There are two ribbon cables that need to be removed in order for the back panel to come free from the camera body, as indicated.
    • This back panel contains various control components of the camera as well as the LCD screen.
  8. Canon EOS Rebel T5 Motherboard Replacement, Motherboard: paso 8, imagen 1 de 1
    • Remove all ribbon cables with the plastic spudger.
    • Gently pry up the black plastic tabs to slide out the ribbon cables
  9. Canon EOS Rebel T5 Motherboard Replacement: paso 9, imagen 1 de 1
    • Turn your camera so that the top is facing you.
    • Remove the two black 5 mm Phillips #000 screws.
  10. Canon EOS Rebel T5 Motherboard Replacement: paso 10, imagen 1 de 3 Canon EOS Rebel T5 Motherboard Replacement: paso 10, imagen 2 de 3 Canon EOS Rebel T5 Motherboard Replacement: paso 10, imagen 3 de 3
    • Turn the grip side toward you.
    • Remove the rubber grip, using the plastic spudger.
  11. Canon EOS Rebel T5 Motherboard Replacement: paso 11, imagen 1 de 1
    • Remove the black 5 mm Phillips #000 screw, located under the grip.
  12. Canon EOS Rebel T5 Motherboard Replacement: paso 12, imagen 1 de 1
    • Remove the top panel of the device.
  13. Canon EOS Rebel T5 Motherboard Replacement: paso 13, imagen 1 de 2 Canon EOS Rebel T5 Motherboard Replacement: paso 13, imagen 2 de 2
    • Remove the front panel of the camera.
  14. Canon EOS Rebel T5 Motherboard Replacement: paso 14, imagen 1 de 3 Canon EOS Rebel T5 Motherboard Replacement: paso 14, imagen 2 de 3 Canon EOS Rebel T5 Motherboard Replacement: paso 14, imagen 3 de 3
    • Remove the five silver 5mm Phillips #000 screws.
    • The motherboard can now be removed.
Conclusión
9 personas más completaron esta guía.
Austin Tucker
Miembro Desde 08/27/15
1,027 Reputación
4 Guías creadas
Equipo
USF Tampa, Team 16-4, Wollert Fall 2015 Miembro de USF Tampa, Team 16-4, Wollert Fall 2015
USFT-WOLLERT-F15S16G4
4 Miembros
16 Guías creadas
2 comentarios
This guide is amazing, but if you change the mainboard do you have to initialize it by software, like Spt?
Edgar Nunes - Contestar
New main board from canon .
How to instalize?
Thomas Nguyen - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 14
Todo El Tiempo: 4,151
