Introducción
If you find that your camera needs a new image sensor, this guide will show you how to replace it.
Qué necesitas
Lay the camera on its back so that the card/battery door is facing you.
Using your fingernail, slide the tab on the battery door up to release the battery door latch.
Turn the camera so that the back is facing to your right.
Remove the 5mm Phillips #000 screw above the rubber USB port cover.
Remove all ribbon cables with the plastic spudger.
Gently pry up the black plastic tabs to slide out the ribbon cables
Remove the three silver 3mm Philips #000 screws from the image sensor holder.
Remove the image sensor holder.
13 personas más completaron esta guía.
3 comentarios
I reassembled on the camera no longer powers on, i checked disassembled again, checked for loose wires, ribbons, everything looks perfect and still it’s completely dead.
