Saltar al contenido principal
Canon EOS Rebel T5 Back Panel Removal
Qué necesitas
  1. Canon EOS Rebel T5 Back Panel Removal, Battery: paso 1, imagen 1 de 1
    • Lay the camera on its back so that the card/battery door is facing you.
    • Using your fingernail, slide the tab on the battery door up to release the battery door latch.
  2. Canon EOS Rebel T5 Back Panel Removal: paso 2, imagen 1 de 1
    • Lift the now free card/battery door to reveal the battery compartment.
    • Push the gray lever to the right side so that the battery can be removed and replaced with a new one.
  3. Canon EOS Rebel T5 Back Panel Removal, Back Panel: paso 3, imagen 1 de 1
    • Turn the camera so that the back is facing to your right.
    • Remove the 5mm Phillips #000 screw above the rubber USB port cover.
  4. Canon EOS Rebel T5 Back Panel Removal: paso 4, imagen 1 de 1
    • Remove the rubber piece.
    • Unscrew the two screws under the rubber cover to completely remove the rubber cover piece.
    • It is held in place by a notched tether, but can be easily manipulated to slide out.
  5. Canon EOS Rebel T5 Back Panel Removal: paso 5, imagen 1 de 1
    • Turn your camera so that the bottom is facing you.
    • Remove the 5mm Phillips #000 screws.
  6. Canon EOS Rebel T5 Back Panel Removal: paso 6, imagen 1 de 1
    • Now turn the camera so that the front is facing towards your right.
    • Remove the two remaining 5mm Phillips #000 screws.
  7. Canon EOS Rebel T5 Back Panel Removal: paso 7, imagen 1 de 3 Canon EOS Rebel T5 Back Panel Removal: paso 7, imagen 2 de 3 Canon EOS Rebel T5 Back Panel Removal: paso 7, imagen 3 de 3
    • Now that all of the exterior screws have been removed, grip the camera firmly on both sides.
    • Gently pry the back panel from the main body of the camera.
    • There are two ribbon cables that need to be removed in order for the back panel to come free from the camera body, as indicated.
    • This back panel contains various control components of the camera as well as the LCD screen.
Conclusión
4 personas más completaron esta guía.
Johnyp
Miembro Desde 08/26/15
254 Reputación
1 Guía escrita
Equipo
USF Tampa, Team 16-4, Wollert Fall 2015 Miembro de USF Tampa, Team 16-4, Wollert Fall 2015
USFT-WOLLERT-F15S16G4
4 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 13
Todo El Tiempo: 3,360
