Saltar al contenido principal
Introducción
This guide will detail the process of replacing the motherboard. Replacing the motherboard is a more involved process and should not be done unless your are sure there is an issue with the motherboard.
  1. Locate the battery cover at the bottom of the camera.
    • Locate the battery cover at the bottom of the camera.
    • Pull down on the black tab to open the cover.
  2. Push the grey tab on the right side of the battery.
    • Push the grey tab on the right side of the battery.
    • Remove the battery from the slot.
  3. Use the spudger to pry off the rubber grip and reveal the screws. Unscrew the four 5.5mm Torx screws using the Torx T6 screwdriver.
    • Use the spudger to pry off the rubber grip and reveal the screws.
    • Unscrew the four 5.5mm Torx screws using the Torx T6 screwdriver.
  4. Pull off the plastic cover from the viewfinder. Unscrew the two 3.4mm Phillips screws using the Phillips #00 screwdriver. Unscrew the two 3.4mm Phillips screws using the Phillips #00 screwdriver.
    • Pull off the plastic cover from the viewfinder.
    • Unscrew the two 3.4mm Phillips screws using the Phillips #00 screwdriver.
  5. Remove the following screws from the device using the Phillips #00 screwdriver:
    • Remove the following screws from the device using the Phillips #00 screwdriver:
    • Three 3.4mm Phillips head screws.
    • One 5.9mm Phillips head screw.
  6. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  7. Remove the following screws from the device using the Phillips #00 screwdriver:
    • One 3.4mm Phillips head screw.
    • One 5.9 mm Phillips head screw.
  8. Remove the rear panel from the camera.
    • Remove the rear panel from the camera.
    • Several fragile cables are attached to the inside of the panel, so remove it gently.
  9. In the lower right corner of the mother board, detach the blue cable. Then detach the ribbon cable going from the motherboard to the rear panel. Then detach the ribbon cable going from the motherboard to the rear panel.
    • In the lower right corner of the mother board, detach the blue cable.
    • Then detach the ribbon cable going from the motherboard to the rear panel.
  10. In the upper left corner of the motherboard, remove the small multicolored wire from the motherboard.
    • In the upper left corner of the motherboard, remove the small multicolored wire from the motherboard.
  11. Use the plastic opening tool to flip up ribbon cable connector. Gently disconnect the ribbon cable by pulling it away from the motherboard. Gently disconnect the ribbon cable by pulling it away from the motherboard.
    • Use the plastic opening tool to flip up ribbon cable connector.
    • Gently disconnect the ribbon cable by pulling it away from the motherboard.
  12. In the upper right corner of the motherboard, use the plastic opening tool to remove the clear cable connector from the motherboard. In the upper right corner of the motherboard, use the plastic opening tool to remove the clear cable connector from the motherboard.
    • In the upper right corner of the motherboard, use the plastic opening tool to remove the clear cable connector from the motherboard.
  13. Use the plastic opening tool to remove the ribbon cable connecting the image sensor to the motherboard. Use the plastic opening tool to remove the ribbon cable connecting the image sensor to the motherboard.
    • Use the plastic opening tool to remove the ribbon cable connecting the image sensor to the motherboard.
  14. Use the plastic opening tool to push on the indents of the plastic header to disconnect from the motherboard. Make sure all cables are disconnected from the motherboard.
    • Use the plastic opening tool to push on the indents of the plastic header to disconnect from the motherboard.
    • Make sure all cables are disconnected from the motherboard.
  15. Remove the following screws from the motherboard using the Phillips #00 screwdriver: Two 3.9mm Phillips head screws.
    • Remove the following screws from the motherboard using the Phillips #00 screwdriver:
    • Two 3.9mm Phillips head screws.
    • Three 2.9mm Phillips head screws
    • Gently pull the motherboard out of the camera.
Conclusión
12 personas más completaron esta guía.
Jordan Rabold
Miembro Desde 14/04/14
679 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 12-33, Maness Spring 2014 Miembro de Cal Poly, Team 12-33, Maness Spring 2014
CPSU-MANESS-S14S12G33
4 Miembros
7 Guías creadas
This guide gets an upvote.
It's the first camera disassembly guide I've seen so far on ifixit that includes the single most important precaution: the camera has a body cap fitted to avoid dust, dirt or other objects getting into the mirror box. Bravo!
Flying Dutchman - Contestar
Where can we buy the parts?
tjt263 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 2
Últimos 7 Días: 10
Últimos 30 Días: 80
Todo El Tiempo: 10,327
