Saltar al contenido principal
Canon EOS Rebel T4i Battery Replacement
  1. Canon EOS Rebel T4i Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Locate the battery cover at the bottom of the camera.
    • Pull down on the black tab to open the cover.
  2. Canon EOS Rebel T4i Battery Replacement: paso 2, imagen 1 de 1
    • Push the grey tab on the right side of the battery.
    • Remove the battery from the slot.
Conclusión
3 personas más completaron esta guía.
Nimisha Patel
Miembro Desde 04/14/14
164 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 12-33, Maness Spring 2014 Miembro de Cal Poly, Team 12-33, Maness Spring 2014
CPSU-MANESS-S14S12G33
4 Miembros
14 Guías creadas
Un comentario
Black tab on cover of the battery is constantly disengaging either when I am using or in my camera bag therefore battery runs down. Seems like a design fault to me. Anyone else having this problem ? Have been using sticky tape to keep it in place but still have a problem with the cover moving around and disengaging battery. Replacing with a new flimsy one from Canon at minimum cost of £40 is not on - knowing it will only happen again. I have given author 30 points for covering the topic but sadly have no idea how to solve this problem
esther allwood - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 27
Todo El Tiempo: 3,052
