Saltar al contenido principal
Canon EOS Rebel T2i Tripod Mount Replacement
Qué necesitas
  1. Canon EOS Rebel T2i Tripod Mount Replacement, Tripod Mount: paso 1, imagen 1 de 2 Canon EOS Rebel T2i Tripod Mount Replacement, Tripod Mount: paso 1, imagen 2 de 2
    • Turn off camera using the power button on the top of the camera.
    • On the bottom of the camera, open the battery door and remove the battery.
  2. Canon EOS Rebel T2i Tripod Mount Replacement: paso 2, imagen 1 de 1
    • Remove the 7 screws from the bottom of the camera using a Phillips screwdriver
  3. Canon EOS Rebel T2i Tripod Mount Replacement: paso 3, imagen 1 de 1
    • Remove the two screws on the right side of the camera.
  4. Canon EOS Rebel T2i Tripod Mount Replacement: paso 4, imagen 1 de 1
    • Remove 1 screw from the left side of the camera.
    • Inside the rubber door, remove the two silver screws.
  5. Canon EOS Rebel T2i Tripod Mount Replacement: paso 5, imagen 1 de 1
    • Remove the two black screws on the front of the camera just above the lens mounting ring.
    • NOTE: Do not remove any of the silver screws on the lens mount ring. This could cause problems with auto focussing features.
  6. Canon EOS Rebel T2i Tripod Mount Replacement: paso 6, imagen 1 de 2 Canon EOS Rebel T2i Tripod Mount Replacement: paso 6, imagen 2 de 2
    • Using the spudger and plastic opening tool, pry the back of the camera loose.
  7. Canon EOS Rebel T2i Tripod Mount Replacement: paso 7, imagen 1 de 1
    • Using the spudger and plastic opening tool, pry the bottom of the front panel of the camera over the tripod mount.
  8. Canon EOS Rebel T2i Tripod Mount Replacement: paso 8, imagen 1 de 2 Canon EOS Rebel T2i Tripod Mount Replacement: paso 8, imagen 2 de 2
    • The screws holding the tripod mount are now exposed.
    • Remove the screws securing the tripod mount
    • With the screws removed, the tripod mount can now be easily pulled free.
Conclusión
Jacob Jaskolka
Miembro Desde 03/30/15
745 Reputación
4 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 1,675
