Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Canon EOS Rebel T2i SD Card Board Replacement
Qué necesitas
  1. Canon EOS Rebel T2i SD Card Board Replacement, I/F Terminal Cover: paso 1, imagen 1 de 3 Canon EOS Rebel T2i SD Card Board Replacement, I/F Terminal Cover: paso 1, imagen 2 de 3 Canon EOS Rebel T2i SD Card Board Replacement, I/F Terminal Cover: paso 1, imagen 3 de 3
    • Before beginning, ensure that the camera is off, and the battery is removed.
    • Pry open the rubber I/F terminal cap with your finger.
    • Remove the two M1.7x2.5mm JIS #000 screws that are underneath the I/F terminal cap.
    • Using a plastic pick, or another thin plastic prying tool, pop off the I/F terminal cover from the camera.
  2. Canon EOS Rebel T2i SD Card Board Replacement, Remove the back casing.: paso 2, imagen 1 de 2 Canon EOS Rebel T2i SD Card Board Replacement, Remove the back casing.: paso 2, imagen 2 de 2
    • On the left side of the camera, remove the following screw:
    • One M1.7x6.0mm JIS #000 screw
    • On the right side, remove the following screws:
    • One M1.7x5.5mm JIS #000 screw
    • One M1.7x3.5mm JIS #000 screw
  3. Canon EOS Rebel T2i SD Card Board Replacement: paso 3, imagen 1 de 2 Canon EOS Rebel T2i SD Card Board Replacement: paso 3, imagen 2 de 2
    • Remove the battery door.
    • Open the battery door to about a 35° angle.
    • Pull the battery door straight outwards.
    • Remove the following screws from the bottom of the camera:
    • Two M1.7x2.5mm JIS #000 screws
  4. Canon EOS Rebel T2i SD Card Board Replacement, Open the back panel.: paso 4, imagen 1 de 3 Canon EOS Rebel T2i SD Card Board Replacement, Open the back panel.: paso 4, imagen 2 de 3 Canon EOS Rebel T2i SD Card Board Replacement, Open the back panel.: paso 4, imagen 3 de 3
    • Slide the viewfinder eyepiece vertically upwards.
    • Start to pull the back cover partially off of the camera.
    • Use caution when removing the back cover, there is a ribbon cable that connects the LCD screen to the main PCB board.
    • Disconnect the LCD screen ribbon cable from the main PCB board.
    • Use a plastic spudger to lift up the black locking tab.
    • Carefully pull out the ribbon cable from its connector using a pair of angled tweezers.
    • Finish pulling the back cover off of the camera body.
  5. Canon EOS Rebel T2i SD Card Board Replacement, Front Cover: paso 5, imagen 1 de 2 Canon EOS Rebel T2i SD Card Board Replacement, Front Cover: paso 5, imagen 2 de 2
    • Remove the following screws from the front of the camera:
    • Two M1.7x5.5mm JIS #000 screws
    • On the bottom of the camera, remove the following screws:
    • Three M1.7x5.5mm JIS #000 screws
  6. Canon EOS Rebel T2i SD Card Board Replacement: paso 6, imagen 1 de 3 Canon EOS Rebel T2i SD Card Board Replacement: paso 6, imagen 2 de 3 Canon EOS Rebel T2i SD Card Board Replacement: paso 6, imagen 3 de 3
    • Slide a spudger tool towards the tripod mount, underneath the plastic cover.
    • Push the plastic cover up and over the tripod mount.
    • Pull the front cover off of the camera.
    • Electric Shock Warning: With the front cover off, the high voltage capacitor on the DC PCB board is now exposed. It is recommended that you use a capacitor discharge tool to ensure the capacitor is fully discharged before proceeding further.
  7. Canon EOS Rebel T2i SD Card Board Replacement, Top Casing: paso 7, imagen 1 de 2 Canon EOS Rebel T2i SD Card Board Replacement, Top Casing: paso 7, imagen 2 de 2
    • Remove the screws next to the viewfinder:
    • One M2.0x8.9mm JIS #000 diopter screw
    • Remove the following screws from the top of the camera:
    • One M1.7x2.5mm JIS #000 screw
    • One M1.7x5.0mm Phillips #000 screw
  8. Canon EOS Rebel T2i SD Card Board Replacement: paso 8, imagen 1 de 2 Canon EOS Rebel T2i SD Card Board Replacement: paso 8, imagen 2 de 2
    • Disconnect the microphone cable from the main PCB board.
    • Position a flathead 2.5mm screwdriver between the main PCB board connector and the microphone connector.
    • Gently wiggle the flathead screwdriver back and forth until the microphone connector comes free.
    • If you do not have a flathead 2.5mm screwdriver, another similarly sized flathead screwdriver should work.
  9. Canon EOS Rebel T2i SD Card Board Replacement: paso 9, imagen 1 de 3 Canon EOS Rebel T2i SD Card Board Replacement: paso 9, imagen 2 de 3 Canon EOS Rebel T2i SD Card Board Replacement: paso 9, imagen 3 de 3
    • Locate the ribbon cable which connects the top cover the main PCB board.
    • Use a plastic spudger tool to carefully pry off the connector.
    • Use caution when handling ribbon connectors and their connectors.
    • Take note of where this fiber optic cable connects to the main PCB board.
    • The cable will slide out of the connector when you pull the top cover off. You will need to remember to slide this cable back into the connector with a pair of tweezers when reinstalling the top cover. This cable is crucial for the function of the camera flash.
  10. Canon EOS Rebel T2i SD Card Board Replacement: paso 10, imagen 1 de 2 Canon EOS Rebel T2i SD Card Board Replacement: paso 10, imagen 2 de 2
    • Disconnect these two cables connected to the DC PCB board.
    • Use the same method as with removing the microphone cable, except with using a flathead 3.0mm screwdriver.
    • Gently wiggle the flathead screwdriver back and forth until the connectors comes free.
    • If you do not have a flathead 3.0mm screwdriver, another slightly larger flathead screwdriver should work.
    • Gently lift the top cover up and off of the camera body, being careful that the loose cables do not snag on anything.
  11. Canon EOS Rebel T2i SD Card Board Replacement, Main PCB Board: paso 11, imagen 1 de 3 Canon EOS Rebel T2i SD Card Board Replacement, Main PCB Board: paso 11, imagen 2 de 3 Canon EOS Rebel T2i SD Card Board Replacement, Main PCB Board: paso 11, imagen 3 de 3
    • Use caution while handling ribbon cables and ribbon cables connects to avoid damaging them.
    • Locate these three ribbon cables located on the left side of the main PCB board.
    • Disconnect the ribbon cables.
    • Two of these ribbon cables features a hole in them which can assist with disconnecting them. Use either a pair of tweezers or another tool with a thin point to pull out the ribbon cables utilizing this hole.
    • Use a plastic spudger tool to carefully push up and disconnect the imaging sensor ribbon cable.
  12. Canon EOS Rebel T2i SD Card Board Replacement: paso 12, imagen 1 de 1
    • Locate the remaining seven ribbon cables connected to the main PCB board.
    • Gently push up on the plastic lock tabs to unlock each of the ribbon cable connectors. Be especially careful with the wide lock tab, as it is particularly fragile.
    • Disconnect each ribbon cable from the main PCB board.
    • iFixit connector guide
  13. Canon EOS Rebel T2i SD Card Board Replacement: paso 13, imagen 1 de 2 Canon EOS Rebel T2i SD Card Board Replacement: paso 13, imagen 2 de 2
    • Remove the following screws on the main PCB board:
    • Three M1.7x2.5mm JIS #000 screws
    • Two M1.7x3.5mm Phillips #000 screws
    • Slide off the metal I/F terminal shield.
  14. Canon EOS Rebel T2i SD Card Board Replacement: paso 14, imagen 1 de 2 Canon EOS Rebel T2i SD Card Board Replacement: paso 14, imagen 2 de 2
    • Tilt the main PCB board upwards to reveal the remaining cable connection.
    • Carefully disconnect the cable.
  15. Canon EOS Rebel T2i SD Card Board Replacement, SD Card Board: paso 15, imagen 1 de 3 Canon EOS Rebel T2i SD Card Board Replacement, SD Card Board: paso 15, imagen 2 de 3 Canon EOS Rebel T2i SD Card Board Replacement, SD Card Board: paso 15, imagen 3 de 3
    • Disconnect the power cable from the SD card board using a 2.5mm screwdriver.
    • Use the same method as you did with the microphone cable on the main PCB board.
    • Carefully remove the ribbon cable from the SD card board using a pair of angled tweezers.
  16. Canon EOS Rebel T2i SD Card Board Replacement: paso 16, imagen 1 de 3 Canon EOS Rebel T2i SD Card Board Replacement: paso 16, imagen 2 de 3 Canon EOS Rebel T2i SD Card Board Replacement: paso 16, imagen 3 de 3
    • Remove the following screws from the SD card board:
    • Four M1.7x3.5mm Phillips #000 screws
    • Remove the SD card board from the camera.
    • Life the top of the SD card board upwards.
    • Slide the SD card board to the right just enough for the board to clear the metal bracket.
    • Be careful not to damage the microswitch on the bottom of the SD card board while removing it.
Conclusión
Documentos Adjuntos
Zephosk
Miembro Desde 09/26/24
5,552 Reputación
39 Guías creadas
Equipo
LGBTQ Technicians Miembro de LGBTQ Technicians
Community
Miembros de 58
101 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 14
Ultimos 30 días: 52
Todo El Tiempo: 445
