Saltar al contenido principal
Canon EOS Rebel T1i Camera Battery Notch Replacement
Qué necesitas
  1. Canon EOS Rebel T1i Camera Battery Notch Replacement, Battery Notch: paso 1, imagen 1 de 2 Canon EOS Rebel T1i Camera Battery Notch Replacement, Battery Notch: paso 1, imagen 2 de 2
    • Locate the side of camera with the HDMI port.
    • Unscrew the 7mm with a JIS #000 screw driver.
  2. Canon EOS Rebel T1i Camera Battery Notch Replacement: paso 2, imagen 1 de 2 Canon EOS Rebel T1i Camera Battery Notch Replacement: paso 2, imagen 2 de 2
    • Use your fingers to gently detach the plastic component from the camera
  3. Canon EOS Rebel T1i Camera Battery Notch Replacement: paso 3, imagen 1 de 3 Canon EOS Rebel T1i Camera Battery Notch Replacement: paso 3, imagen 2 de 3 Canon EOS Rebel T1i Camera Battery Notch Replacement: paso 3, imagen 3 de 3
    • Unscrew the bottom three 4mm screws with a JIS #000 screwdriver.
  4. Canon EOS Rebel T1i Camera Battery Notch Replacement: paso 4, imagen 1 de 1
    • Unscrew the inner 4mm screw with a JIS #000 screwdriver.
  5. Canon EOS Rebel T1i Camera Battery Notch Replacement: paso 5, imagen 1 de 2 Canon EOS Rebel T1i Camera Battery Notch Replacement: paso 5, imagen 2 de 2
    • Unscrew the top 7mm screw on the right side of the camera.
    • Unscrew the bottom 4 mm screw on the right side of the camera.
  6. Canon EOS Rebel T1i Camera Battery Notch Replacement: paso 6, imagen 1 de 3 Canon EOS Rebel T1i Camera Battery Notch Replacement: paso 6, imagen 2 de 3 Canon EOS Rebel T1i Camera Battery Notch Replacement: paso 6, imagen 3 de 3
    • Use the plastic opening tool to pry open the entire back panel.
    • Use your fingers to pull off the back panel.
  7. Canon EOS Rebel T1i Camera Battery Notch Replacement: paso 7, imagen 1 de 3 Canon EOS Rebel T1i Camera Battery Notch Replacement: paso 7, imagen 2 de 3 Canon EOS Rebel T1i Camera Battery Notch Replacement: paso 7, imagen 3 de 3
    • Now that the panel is off, unscrew the 9mm screw holding the battery notch in.
    • Use the pliers (or your fingers) to take off the white notch.
    • There is a spring underneath the battery notch. Do not lose this spring or let it fall off.
Conclusión
4 personas más completaron esta guía.
Jonathan Lin
Miembro Desde 04/14/14
548 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 3-41, Maness Spring 2014 Miembro de Cal Poly, Team 3-41, Maness Spring 2014
CPSU-MANESS-S14S3G41
Miembros de 4
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 61
Todo El Tiempo: 3,391
