Saltar al contenido principal
Canon EOS Rebel G Strap Anchors Replacement
Qué necesitas
  1. Canon EOS Rebel G Strap Anchors Replacement, Front Panel: paso 1, imagen 1 de 1
    • Using a #00 Phillips screw driver, remove three 4.4 mm Phillips screws as indicated by the red circles.
  2. Canon EOS Rebel G Strap Anchors Replacement: paso 2, imagen 1 de 2 Canon EOS Rebel G Strap Anchors Replacement: paso 2, imagen 2 de 2
    • Using your finger, peel back the textured grip so the components are separated.
  3. Canon EOS Rebel G Strap Anchors Replacement: paso 3, imagen 1 de 3 Canon EOS Rebel G Strap Anchors Replacement: paso 3, imagen 2 de 3 Canon EOS Rebel G Strap Anchors Replacement: paso 3, imagen 3 de 3
    • Using the flat end of a spudger, loosen the connection between the front panel and the device.
    • Remove the front panel using your hands.
  4. Canon EOS Rebel G Strap Anchors Replacement, Top Panel: paso 4, imagen 1 de 1
    • Turn Camera over.
    • Using a #00 Phillips screw driver, unscrew the two 4.9 mm Phillips screws located on either side of the viewfinder.
  5. Canon EOS Rebel G Strap Anchors Replacement: paso 5, imagen 1 de 1
    • Using a #00 Phillips screw driver, unscrew the one 5.7 mm Phillips screw located next to the LCD screen.
  6. Canon EOS Rebel G Strap Anchors Replacement: paso 6, imagen 1 de 1
    • Lay the camera on its back.
    • Unsolder the flash connection from the motherboard as noted by the blue circle.
  7. Canon EOS Rebel G Strap Anchors Replacement: paso 7, imagen 1 de 3 Canon EOS Rebel G Strap Anchors Replacement: paso 7, imagen 2 de 3 Canon EOS Rebel G Strap Anchors Replacement: paso 7, imagen 3 de 3
    • Remove the top panel by lifting it from the back, pushing it forward over the camera and letting it rotate down in front of the camera.
  8. Canon EOS Rebel G Strap Anchors Replacement, Strap Anchors: paso 8, imagen 1 de 1
    • Unscrew the 6.8 Phillips screw that holds the strap anchor by the LCD.
  9. Canon EOS Rebel G Strap Anchors Replacement: paso 9, imagen 1 de 1
    • Unscrew the screws that hold the remaining strap anchor.
    • Two 4.9 mm Phillips screws
Conclusión
Kyle Reis
Miembro Desde 04/02/12
52 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 14-9, Forte Spring 2012 Miembro de Cal Poly, Team 14-9, Forte Spring 2012
CPSU-FORTE-S12S14G9
5 Miembros
36 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 1,150
