Saltar al contenido principal
Canon EOS Rebel G Lens Connector Replacement
Qué necesitas
  1. Canon EOS Rebel G Lens Connector Replacement, Front Panel: paso 1, imagen 1 de 1
    • Using a #00 Phillips screw driver, remove three 4.4 mm Phillips screws as indicated by the red circles.
  2. Canon EOS Rebel G Lens Connector Replacement: paso 2, imagen 1 de 2 Canon EOS Rebel G Lens Connector Replacement: paso 2, imagen 2 de 2
    • Using your finger, peel back the textured grip so the components are separated.
  3. Canon EOS Rebel G Lens Connector Replacement: paso 3, imagen 1 de 3 Canon EOS Rebel G Lens Connector Replacement: paso 3, imagen 2 de 3 Canon EOS Rebel G Lens Connector Replacement: paso 3, imagen 3 de 3
    • Using the flat end of a spudger, loosen the connection between the front panel and the device.
    • Remove the front panel using your hands.
  4. Canon EOS Rebel G Lens Connector Replacement, Lens Connector: paso 4, imagen 1 de 1
    • Using a Phillips #00 screwdriver, remove the 5 indicated screws
    • Five 6.2 mm Phillips screws
  5. Canon EOS Rebel G Lens Connector Replacement: paso 5, imagen 1 de 1
    • Using your hands, remove the top black ring.
    • WARNING! The indicated piece is spring loaded. Prepare for it to eject when taking off top ring.
    • Spring located here.
  6. Canon EOS Rebel G Lens Connector Replacement: paso 6, imagen 1 de 2 Canon EOS Rebel G Lens Connector Replacement: paso 6, imagen 2 de 2
    • There are two silver metal rings.
    • Remove the top silver metal ring.
  7. Canon EOS Rebel G Lens Connector Replacement: paso 7, imagen 1 de 1
    • Remove the bottom silver ring.
Conclusión
2 personas más completaron esta guía.
Zach
Miembro Desde 04/04/12
46 Reputación
8 Guías creadas
Equipo
Cal Poly, Team 14-9, Forte Spring 2012 Miembro de Cal Poly, Team 14-9, Forte Spring 2012
CPSU-FORTE-S12S14G9
Miembros de 5
36 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 10
Todo El Tiempo: 1,895
