Introducción
This guide shows you how to install a new LCD screen.
Herramientas
Partes
No se requieren partes.
Using a #00 Phillips screw driver, remove three 4.4 mm Phillips screws as indicated by the red circles.
Turn Camera over.
Using a #00 Phillips screw driver, unscrew the two 4.9 mm Phillips screws located on either side of the viewfinder.
Pry off the small metal brace holding the LCD screen. (Push forward and slide toward the center)
