Saltar al contenido principal
Canon EOS A2 Front Cover Replacement
Qué necesitas
  1. Canon EOS A2 Front Cover Replacement, Battery: paso 1, imagen 1 de 1
    • Locate the battery door/camera grip on the left side of the camera and lift the rotating removal tab.
  2. Canon EOS A2 Front Cover Replacement: paso 2, imagen 1 de 1
    • Twist the tab clockwise to unlock the door, then pull outward from the camera to remove it.
  3. Canon EOS A2 Front Cover Replacement: paso 3, imagen 1 de 1
    • Remove the battery from inside the battery housing and set the cover aside.
  4. Canon EOS A2 Front Cover Replacement, Front Cover: paso 4, imagen 1 de 1
    • Remove the two 6.4mm screws above the lens aperture using a phillips #00 screw driver.
  5. Canon EOS A2 Front Cover Replacement: paso 5, imagen 1 de 1
    • Remove the 6.4mm screw from the inside of the flash bezel.
    • If the flash is locked down, insert the battery, then with the help of a pencil turn the rotary (CW or CCW) switch until the "125" is displayed in the LCD. Press the Flash symbol button. You should hear the latch from the flash, then you can manually lift the flash. If OK, then remove the battery from the camera
  6. Canon EOS A2 Front Cover Replacement: paso 6, imagen 1 de 1
    • Flip the camera upside down and remove the 5.4mm screw below the lens bezel on the front of the camera.
  7. Canon EOS A2 Front Cover Replacement: paso 7, imagen 1 de 1
    • Remove the 5.6mm screws behind the battery cover.
  8. Canon EOS A2 Front Cover Replacement: paso 8, imagen 1 de 1
    • Remove two 6.4mm screws on the latch mechanism on the right side of the camera.
  9. Canon EOS A2 Front Cover Replacement: paso 9, imagen 1 de 1
    • Remove the 6.4mm screw on the top of the inside edge of the battery hole.
  10. Canon EOS A2 Front Cover Replacement: paso 10, imagen 1 de 2 Canon EOS A2 Front Cover Replacement: paso 10, imagen 2 de 2
    • Starting at the flash, carefully pull the front cover away from the camera.
Conclusión
Mark
Miembro Desde 04/20/11
192 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 8-9, Regan Spring 2011 Miembro de Cal Poly, Team 8-9, Regan Spring 2011
CPSU-REGAN-S11S8G9
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 11
Todo El Tiempo: 2,627
