Saltar al contenido principal
Canon EOS 70D EFS 18-135mm Lens Main Board Replacement
Qué necesitas
  1. Canon EOS 70D EFS 18-135mm Lens Main Board Replacement, EFS 18-135mm Lens Main Board: paso 1, imagen 1 de 3 Canon EOS 70D EFS 18-135mm Lens Main Board Replacement, EFS 18-135mm Lens Main Board: paso 1, imagen 2 de 3 Canon EOS 70D EFS 18-135mm Lens Main Board Replacement, EFS 18-135mm Lens Main Board: paso 1, imagen 3 de 3
    • First, detach the lens by pressing and holding the release button highlighted in the picture.
    • Next, grab the lens and rotate it counter-clockwise when looking at the camera.
    • Finally, when the camera stops rotating, pull the lens away from the camera.
  2. Canon EOS 70D EFS 18-135mm Lens Main Board Replacement: paso 2, imagen 1 de 2 Canon EOS 70D EFS 18-135mm Lens Main Board Replacement: paso 2, imagen 2 de 2
    • Remove the four 5.5-mm Phillips #000 screws for the lens mount ring (silver ring).
    • Remove the two 4-mm Phillips #000 screws mounting the main board connector.
    • This guide involves removing a lot of very small screws so be sure to have a magnet board to keep track of them.
  3. Canon EOS 70D EFS 18-135mm Lens Main Board Replacement: paso 3, imagen 1 de 2 Canon EOS 70D EFS 18-135mm Lens Main Board Replacement: paso 3, imagen 2 de 2
    • Using a spudger, pull the connector loose from the barrel switch ring assembly.
    • Set barrel switch ring assembly to the side.
  4. Canon EOS 70D EFS 18-135mm Lens Main Board Replacement: paso 4, imagen 1 de 2 Canon EOS 70D EFS 18-135mm Lens Main Board Replacement: paso 4, imagen 2 de 2
    • Using a spudger, pull the five connectors out of their housing.
    • Use very gentle pressure when pulling connectors out of the lens main board, as they tend to break easily.
  5. Canon EOS 70D EFS 18-135mm Lens Main Board Replacement: paso 5, imagen 1 de 3 Canon EOS 70D EFS 18-135mm Lens Main Board Replacement: paso 5, imagen 2 de 3 Canon EOS 70D EFS 18-135mm Lens Main Board Replacement: paso 5, imagen 3 de 3
    • Remove the two 4-mm Phillips #000 main board mounting screws.
    • Remove the main board from the lens with your hand.
    • The main board is now successfully removed from the lens.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 30
Todo El Tiempo: 2,347
