Saltar al contenido principal
Canon EOS 6D Rear LCD Screen Replacement
Qué necesitas
  1. Canon EOS 6D Rear LCD Screen Replacement, Rear Body Panel: paso 1, imagen 1 de 1
    • Remove the viewfinder cover by pinching the sides and sliding it upward.
  2. Canon EOS 6D Rear LCD Screen Replacement: paso 2, imagen 1 de 1
    • Open the battery door on the bottom of the camera.
    • Use your thumb to slide the small black tab on the inside of the battery door up and pull the door off the camera.
  3. Canon EOS 6D Rear LCD Screen Replacement: paso 3, imagen 1 de 1
    • Slide your fingernail or the flat end of the spudger underneath the rubber covering and gently peel it off all sides of the camera.
  4. Canon EOS 6D Rear LCD Screen Replacement: paso 4, imagen 1 de 1
    • Open the covers to the HDMI/AV/MIC ports on the side of the camera by gently pulling outward on the bottom of the covers.
    • Rotate the covers to the side so that you can see the connection ports inside.
    • Remove the following screws:
    • Two silver 5mm Phillips #00
    • One black 6mm Phillips #00
  5. Canon EOS 6D Rear LCD Screen Replacement: paso 5, imagen 1 de 1
    • Remove the cover to the HDMI/AV/MIC ports by gently lifting the tab on the bottom edge of the camera.
  6. Canon EOS 6D Rear LCD Screen Replacement: paso 6, imagen 1 de 1
    • Rotate your camera so the bottom side is facing you.
    • One 6mm Phillips #00
    • Two 3mm Phillips #00
  7. Canon EOS 6D Rear LCD Screen Replacement: paso 7, imagen 1 de 1
    • Rotate your camera so the back is facing you.
    • Three silver 5mm Phillips #00
    • Two black 6mm Phillips #00
    • One black 4mm Phillips #00
  8. Canon EOS 6D Rear LCD Screen Replacement: paso 8, imagen 1 de 2 Canon EOS 6D Rear LCD Screen Replacement: paso 8, imagen 2 de 2
    • A black ribbon wire connects the rear panel to the inside of the camera. Breaking this wire would make your rear screen and buttons non-functional.
    • Carefully use your fingers to tilt the back panel downward to about a 90 degree angle.
    • Use the flat end of the spudger to gently pry off the ribbon wire from the inside of the camera.
  9. Canon EOS 6D Rear LCD Screen Replacement, Rear LCD Screen: paso 9, imagen 1 de 1
    Herramienta utilizada en este paso:
    • Detach the two light brown ribbon wires from the back of the LCD screen by firmly gripping each with tweezers and gently pulling straight to the left.
  10. Canon EOS 6D Rear LCD Screen Replacement: paso 10, imagen 1 de 1
    • Remove three 3mm Phillips #00 screws from the inside of the panel.
  11. Canon EOS 6D Rear LCD Screen Replacement: paso 11, imagen 1 de 1
    • Carefully peel the black tape off the upper edge of the screen (not shown).
    • Remove the screen by using the flat edge of the spudger to carefully lift the screen assembly off its silver aligning pins.
Conclusión
12 personas más completaron esta guía.
Justin Thomas
Miembro Desde 04/22/14
2,188 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 11-48, Amido Spring 2014 Miembro de Cal Poly, Team 11-48, Amido Spring 2014
CPSU-AMIDO-S14S11G48
Miembros de 4
18 Guías creadas
5Guía Comentarios
Thank you! Thank you!! I rescued my 6D. All your steps and details were very useful.
Few points to add:
1. I think the black screw (yellow circle) from step 7 is 3 mm.
2. Lift the light brown flap that holds the ribbon cable before removing the LCD panel.
3. When you remove the LCD panel from the metal housing, you will have to pry the two strips of adhesive that is there.
4. Be careful when tightening the screws back.
Chandana Sembakutti - Contestar
Please add to setp 8: The ribbon cable is connected to the camera via a plug (the gold colored PCB has a male plug on the other side of the PCB). This plug is at the end of the spudger. You need to pull that PCB boar/plug straight up from the camera (perpendicular to the camera)
Jim R - Contestar
Is there a guide for changing the protective screen on the back of the camera only? Like when it's scratched or cracked and the lcd works just fine?
joe smith - Contestar
Could you help me to find the reference of the lcd screen
Roger Paucton
Paucton - Contestar
Could you help me to find the reference of the lcd screen ?
Roger Paucton
Paucton - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 19
Ultimos 30 días: 136
Todo El Tiempo: 20,749
