Introducción
Use this guide to replace the rear body panel of your EOS 6D or to access damaged internal components.
Qué necesitas
Remove the viewfinder cover by pinching the sides and sliding it upward.
Open the covers to the HDMI/AV/MIC ports on the side of the camera by gently pulling outward on the bottom of the covers.
Rotate the covers to the side so that you can see the connection ports inside.
Remove the following screws:
Two silver 5mm Phillips #00
One black 6mm Phillips #00
11 personas más completaron esta guía.
2 comentarios
Thanks alot, very helpful
Thanks alot, very helpful fixed an issue
